OBD1 LSVtec Turbo Questions...
Old Dec 22, 2009 | 02:18 PM
TurboEG6OneFive's Avatar
Default OBD1 LSVtec Turbo Questions...
Ok so I boosted the LSv, put a new competition Iron Man clutch in it drove 300 miles just to see what its got and the car **** on me. It acts like it might have a boost leak somewhere, but it won't barely build 5 lbs. and it's not hitting vtec. It just hesitates after about 4psi of boost. I know I probably need to re-gap my plugs to 30ish, but I didnt know if it would make that big of a difference.
I'm running all stock internals, garrett t3 turbo, tubular manifold, pricision intercooler, 450 dsm injectors, and a p72 on Chrome with a street tune for 8.8lbs. I wasn't sure if the ECU tune would eliminate the MAP sensor missing link ordeal or if I needed one regardless. Any help would be greatly appreciated. If it's not the missing link I'm guessing there is a boost leak I haven't found yet or the spark plug gap issue. Either way its struggling with boost and not hitting vtec as far as I can tell. I had a poormans type r not hit vtec on me one time when it came unplugged and it feels about the same, just alot of hesitation.
Old Dec 22, 2009 | 03:23 PM
tegman23's Avatar
Default Re: OBD1 LSVtec Turbo Questions...
is it throwins any codes? the car was tuned for that exact setup?
Old Dec 22, 2009 | 06:00 PM
GEN2 LS's Avatar
Loved
check the dizzy. sometimes we have had a few cars with the igniter go bad and have similar issues.
Old Dec 23, 2009 | 10:28 AM
the computer was tuned for a GSR, but the same exact injectors and everything. No CEL... Some people think it is because I hooked the exhaust up, but I don't think it would make this big of a difference. It is downpipe into flex pipe into high flow cat into 2.5" straight pipe Apexi Worldsport2. I can't even get it out right now for all the snow so I'm just trying to get a couple ideas of what it could be.
Old Dec 23, 2009 | 10:30 AM
Does anyone know if the spark plugs being gapped around 50 would make it hesitate?
I never gapped them from where they were at all motor.
Old Dec 23, 2009 | 11:52 AM
kyden's Avatar
you should not be running a missing link with crome.
Old Dec 23, 2009 | 12:33 PM
boostedEF91's Avatar
A missing link is for someone running a FMU that has to hide boost so the map sensor cant read it you shouldnt have a Missing link with a chipped ecu. Your plugs should be gaped at 23-27. NOT 50. you obviously have no clue what your doing here. And from what you are saying your car was never tuned. you bought a ecu that had someone elses tune on it?? thats a NO NO. you need a tune if you havent gotten a tune for your car Cant be using someone elses. same setup or not thats just laziness.
Old Dec 23, 2009 | 02:37 PM
Yea thanks for the help man, I'm not retarded, I have had a turbo car before. I'm just asking questions cause I didn't figure everyone would be a douche bag about it. I don't have a bunch of money to throw at my cars like most so give me a break man. I just stated that I hadn't had a chance to look at it for all the snow up here so i figured I would ask around. I fixed a major boost leak today and it pulls fine now. I just need a straight answer on what exactly not gapping your plugs properly would do. Blow the spark out and cause detonation?
Old Dec 23, 2009 | 02:52 PM
D-Clem's Avatar
wow.
Ricardo Aguayo
Engine Management and Tuning
Oct 5, 2018 03:52 PM
elmalo
May 2, 2009 05:27 PM
Luward
Apr 29, 2008 04:46 AM
18gLUDE
Jan 13, 2008 04:14 PM
1990hondaHF
Aug 13, 2005 10:37 PM
