quick eg ecu question
Old Nov 6, 2009 | 04:39 PM
Show15's Avatar
Default quick eg ecu question
alright i have a d15b7 which i believe is supposed to come with the p06 ecu. Correct me if im wrong. i have p05 ecu. would this in any way effect the way my motor runs? the p05 came with the d15b8 which originally was in my car
Old Nov 6, 2009 | 05:40 PM
CivicSpoon's Avatar
Default Re: quick eg ecu question
Yes it will effect it. The P05 is meant to run a 70hp 8-valve engine, compared to the 100 something hp 16-valve engine you have in there now. So your fuel and timing maps are going to be off.
Old Nov 6, 2009 | 05:44 PM
Show15's Avatar
thats what i thought. thanks
Old Nov 7, 2009 | 10:46 AM
Show15's Avatar
what are the possible side effect of running a p05 instead of the correct p06. i bought a p06 off of a guy (Big J Jdm) and he said it was manual. it wasnt. would it be better to run the p06 or p05? my car runs alot better with the p05. and the p06 is throwing a lock up selinoid cel. but i believe that becuase i dont have an auto
Old Nov 7, 2009 | 11:49 AM
thumper64's Avatar
The auto ECU can be converted. If takes all of 2 minutes if you have a soldering iron. One resistor is removed, another is replaced with a 0ohm resistor.
Old Nov 7, 2009 | 04:01 PM
Show15's Avatar
Is there a write up for this? I'm at work on my phone so I can't look it up right now
Old Nov 7, 2009 | 08:34 PM
Show15's Avatar
i found one. so if i mod this ecu thatll work? should i take the other auto parts out too?
ehrkeith
Mar 18, 2012 12:52 PM
purple98ek
10
Jun 5, 2007 12:01 AM
prelewd
Feb 9, 2006 03:56 PM
Btothe3rdDegree
Jun 27, 2004 06:51 PM
89 JDM CRX
Mar 8, 2004 10:10 PM
