99-00 si harness??
Old Nov 2, 2009 | 04:50 PM
94eh2's Avatar
Default 99-00 si harness??
ok i just bought a 99 si harness and noticed that it only has 2 ecu plugs along with the green connector but my 99 ex harness has 3 ecu plugs along with the green connector. can i still use this even tho it has only 2 ecu plugs? i will be dropping a gsr into my 99 ex coupe. i have a obd2b jumper harness. will it still work?
Old Nov 2, 2009 | 09:29 PM
94eh2's Avatar
Default Re: 99-00 si harness??
bumppp
Old Nov 2, 2009 | 09:42 PM
BrownDx's Avatar
The third plug comes from under the dash. I was also scratching my head when I bought a si harness.
Old Nov 2, 2009 | 09:51 PM
geneeunit's Avatar
99-00 is OBD2b whereas 96-98 is OBD2a.. so you just need to use the engine harness, and plug it into your underdash(green plug).. obd2b is what you have so the jumper harness is cool.
da59block
14
Nov 11, 2011 12:33 PM
tdbhonda
Mar 17, 2009 09:05 AM
HondaPartsHero
13
Nov 24, 2006 09:30 PM
eeyore357
Jul 5, 2005 10:52 PM
EEK
Jul 11, 2002 09:35 AM
