Starting Issues
Old Oct 20, 2009 | 06:03 PM
omgwtfbbq's Avatar
Default Starting Issues
1994 Honda Civic EX
bone stock
Problem: If my car sits for more than a day, it won't start. When I turn the key on, I have full display, but it doesnt crank. After clutching it a few times, and turning it, it will start....sometimes I have to do this process two or three times. Considering it doesnt crank and I have full power, I'm guessing it's the clutch switch.
But here is where I am lost. After it starts, I can turn it off, and let it sit for 1 minute, 4 hours, etc. and it will start....unless I let it sit for more than 24 hours, then I have trouble getting it to crank. If it were the switch, wouldn't it do it all the time, rather than only after prolonged amounts of time?
any help would be appreciated. thanks.
Old Oct 20, 2009 | 06:26 PM
Former User's Avatar
Default Re: Starting Issues
Jump the 2P connector of the clutch switch. If this prevents the start problem, then replace the switch.
Warning: Jumping the clutch switch bypasses a safety device, so make sure the transmission is in neutral when you start the engine.
Old Oct 20, 2009 | 06:35 PM
omgwtfbbq's Avatar
I know how to jump the connector, and I know the dangers of it (ive done a few auto to manual swaps). Anyway, after I get it started, I have no problems. So I dont know how jumping the connector can be a controlled experiement. I guess I have to do it next time it gives me trouble starting.
I guess I'll try it out. I'll keep you updated. Thanks Ron.
Old Oct 20, 2009 | 06:48 PM
You'll need to leave the connector jumped for a period of time in which the start problem would typically happen a couple of times. If the problem doesn't occur during this time, then you would assume that the clutch switch is bad.
If the switch is fine, then you may want to test the ignition switch.
Nikki Aulicino
Jan 26, 2017 10:25 PM
magicmyst98
14
Sep 2, 2013 12:06 PM
lilmarcEH3
10
Sep 1, 2010 10:01 AM
wambus
Jul 14, 2006 01:12 PM
M-EJ1
Dec 15, 2002 06:24 PM
