Lean vs Rich
Old Aug 27, 2002 | 02:24 PM
B00ST2nR's Avatar
Default Lean vs Rich
Ok. So what exactly happens when you run too lean or too rich? Does it cause a big problem?
Old Aug 27, 2002 | 03:40 PM
jdmillusion's Avatar
Default Re: Lean vs Rich (Skunk2nR)
i owned an 88 supra. i was 16 at that time, driving it like i just bought it. unknowingly i was running lean. 3 months later, my mother had to pay to get the block rebuilt and purchased a rebuilt head as well. she ended up paying 1k for everything. learned from that mistake.
just something to be watching for with situations like these.
Old Aug 27, 2002 | 03:53 PM
Leb_CRX's Avatar
Default Re: Lean vs Rich (jdmillusion)
lean you'll detonate, and put a hole in your piston
rich aint that bad but you'll coat your cylinder walls with gasoline after a while, adn **** up your piston rings, and you'll start smoking
|eb_CRX
sparkz's Avatar
Running to lean mean high temps. You can melt pistons and fry rings. Fried rings means messedup cylinder walls. Runnign too rich.. well it'll clogg your cat and suck your wallet dry for gas guzzling.
Old Aug 27, 2002 | 06:51 PM
Comptech98GSR's Avatar
Default Re: Lean vs Rich (sparkz)
also your engine should run cooler, if you are running rich, and you would be putting out alot of black smoke, when u get on the gas, or u could smell the unburnt fuel, also check your spark plugs to be able to tell.
Old Aug 27, 2002 | 08:05 PM
lazy bum shaughn's Avatar
I hear air/fuel ratio gauges aren't too accurate, so they say to get an EGT(exhaust temp.) gauge. But what should the temperature be on when you're running normal(stoich or whatever it's called)? And what's the temperature when you're too rich or lean?
Old Aug 27, 2002 | 09:09 PM
Leb_CRX's Avatar
Default Re: Lean vs Rich (Mixxed Bboy)
nope a normal o2 is crap...a wideban o2 is useful, but not worth it imo
as for EGT guage...kind of less useless, but still useless in a way, the problem with it is that say you run lean for a min...by the time the guage shows you taht your lean you would have blown your motor...that's under heavy circumstance, if you wanna see if your runnin a bit lean...I dont know how to say the term, but by the time the guage shows it, you lose a lot of time...meh there's a ****** term, can't figure it out
Old Aug 27, 2002 | 10:09 PM
tinkerbell's Avatar
something that uses a zirconia element that produces a reference voltage used by the ECM/PCM is pretty accuate way to measure A/F ratios.
a set of LEDS (light emitting diodes) that measures this 0.01 to 0.9V signal is going to be fairly accurate for non-tuning purposes.
eg in car monitoring whilst driving...
that is, it is usefully to detect gross fluctuations in A/F ratios...
but hey, why the rant?
i dunno, maybe cause i never heard that A/F gauges wernt accurate before?
are they or arnt they?
t..
Old Aug 27, 2002 | 10:59 PM
raene's Avatar
Default Re: Lean vs Rich (tinkerbell)
Air/fuel gauges show trends but not exactness.
preludedriva
Aug 28, 2007 07:32 AM
504tuner
Feb 8, 2005 05:25 PM
tub_sephiroth
Sep 17, 2004 10:17 PM
EG6AAARRR!!!
Aug 22, 2004 07:42 AM
homesauce
Dec 3, 2003 02:15 AM
