what are these pins for on the interior fusebox?
Old Sep 11, 2009 | 12:13 PM
ketchup's Avatar
Default what are these pins for on the interior fusebox?
Curious to find out what those are/can be used for.
Old Sep 11, 2009 | 12:48 PM
ketchup's Avatar
Default Re: what are these pins for on the interior fusebox?
bump, forgot to upload the pic lol.
Old Sep 11, 2009 | 02:36 PM
mother ef-er's Avatar
the last two on the right in your red circle are for the fuse puller. its a little black tool that comes stock with the car. those two spaces can be used to hold your fuse puller.
the other three.. not sure bro.
Old Sep 11, 2009 | 02:53 PM
ketchup's Avatar
Lol thanks for pointing out the fuse puller spot.
I think they are for accessories and supply power.
Old Sep 11, 2009 | 03:51 PM
apekd's Avatar
those three spots are actually a source for constant power. put a test light on it and ground and check it out. You'll see
Old Sep 11, 2009 | 03:59 PM
intense4thgen's Avatar
constant power ,switched and running lights
Old Sep 11, 2009 | 04:05 PM
apekd's Avatar
^thats right i forgot about the running lights. lol
Old Sep 11, 2009 | 08:46 PM
ketchup's Avatar
There are actually 5. 2 up top (1, 2) then those 3 (3, 4, 5).
So 3, 4, 5, are constant, switch, and running lights? in that order?
Old Sep 12, 2009 | 08:55 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Wrong... they are not in that order I am curious where people ge their information from...
1. = 12v Key Position 2
2. = 12v Light Switch Activated (turn pos. & headlight pos.)
3. = 12v Key Position 1 & 2
4. = ??? I am not sure and I am pretty sure it is not a ground...
5. = 12v Constant
Old Sep 12, 2009 | 09:58 AM
ketchup's Avatar
5. = 12v Constant
You're the man!
Lol pretty sure its not a ground eh?
Old Sep 12, 2009 | 10:33 AM
DO IT ON ALL FOURS
Well I tested it and I can't get voltage from it either positive or negative going through the motions. So I took a test light and hooked it up both ways (positive source and negative source). Then I cycled through the key positions (yes, even pos. 3 (start)). I could not get it to function as anything be it ground or positive source in any key position. It must be for something else or is switched by something else. I personally was really hoping it would be a ground.
Gatschet
23
Aug 25, 2021 10:35 AM
mcleary333
Nov 30, 2013 04:39 PM
hiredassasin19
20
Apr 5, 2010 12:55 PM
Luke G.
10
Sep 27, 2009 08:32 AM
wicked_gk
Sep 18, 2009 12:49 PM
