Will a y8 block work
Old Jun 14, 2009 | 09:55 PM
Novtec4u's Avatar
Default Will a y8 block work
I got a 1993 Honda Civic EX . The block is junk but the head and etc is good. Can I put the z6 head on a y8 block . What all would I need? z6 or y8 head studs? I can use my z6 dizzy and the whole top end correct. Please fill me in.
Old Jun 14, 2009 | 10:02 PM
TravisCadello's Avatar
Default Re: Will a y8 block work
Your 93 civic ex should had came with a d16z6 not the d16y8. the y8 is for 96-00
Old Jun 14, 2009 | 10:03 PM
slow96lude's Avatar
correcto mundo on the head will work on the y8 block but as to the studs im not sure. i would think that either one will work but check the deck heights on both and see which ones you need.
Old Jun 14, 2009 | 10:04 PM
0 0K!!! sorry man its late. i get you now. ok the d16y8 block and d16z6 block are exactly the same except the y8 block sux because their prone to spinning rod bearings. but is still a good block just z6 is better.
Ok, their exactly the same man, so you gonna put a d16y8 block in it will bolt right up with your z6 tranny and all and the head if your putting a z6 head on just use the original z6 head bolts. the y8 head bolts are way shorter and will not work.
Good Luck!
Old Jun 15, 2009 | 12:02 AM
FearTheH's Avatar
make sure after you get it together that you put plenty of hot sauce, laundry detergent and rocks in there to keep it running like a top! sorry, had to do it...
Old Jun 15, 2009 | 12:29 AM
NACvicSi's Avatar
Why does your avatar say no Vtec, but you have a Z6?
Old Jun 15, 2009 | 02:00 AM
Davus's Avatar
A quart low all the time would be my guess, given the situation with his engine block being screwy. :-)
Old Jun 15, 2009 | 02:31 AM
NACvicSi's Avatar
^ lmao
Old Jun 15, 2009 | 05:37 AM
Novtec4u's Avatar
I was asking for a friend lol.
Old Jun 15, 2009 | 09:05 AM
CivicSpoon's Avatar
Head studs to use: https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/d16z6-head-onto-d16y7-d16y5-d16y8-block-d16y8-head-d15b7-d16z6-block-head-bolts-stu-1635057/
93turbo16
Mar 19, 2012 11:38 AM
straightshot08
Nov 9, 2009 01:59 PM
Cruiser G
Sep 19, 2009 09:43 PM
milruner
Dec 29, 2003 07:13 AM
bluedelsol
Jun 8, 2003 06:46 PM
