ek harnes question
Old Jun 12, 2009 | 02:22 PM
egb20v's Avatar
Default ek harnes question
Ok i'm kinda new to this forum.....i tried searching but culdnt quite come up with what i was looking for..... so if the info i am looking for is all over these forums please help me find it!!! I am new to the ek thing and have a question about the wiring. i know its a one peice harness, unlike the eg/dc.... so i have a 97 dx coupe and i'm purchasing a b18c sir-g swap, obviously i cant use the harness that will come with it! can i use an ex harness or si harness and skip the mess of hacking up my OE dx harnes???? srry in advance for everyone who i gonna tell me this has been covered, hundreds, thousands, millions of times....please forgive!!
Old Jun 12, 2009 | 02:38 PM
geneeunit's Avatar
Default Re: ek harnes question
96-98 ex harness or i think an hx harness would be your best bet..
IF!! you dont want to add wires to your dx harness. most people recommend using the harness that came with the car. if you used a 99-00 harness, you also have to change the underdash harness, and a few other things. i recommend sticking with a 96-98 harness OBD2a..
Old Jun 12, 2009 | 02:42 PM
egb20v's Avatar
ok thank you for the fast reply.... so the ecu plugs DIRECTLY into the harness?
Old Jun 12, 2009 | 03:06 PM
egb20v's Avatar
is there anyone with an ek who has swapped a gsr into their ek(dx) and used a different harness???
Old Jun 12, 2009 | 03:53 PM
egb20v's Avatar
anyone???? at all?
Old Jun 12, 2009 | 04:09 PM
geneeunit's Avatar
depends on the year of the motor.. if your motor is OBD2a or OBD2b, OBD1.. if it is, you'll need a conversion harness, or you CAN re-pin the plugs if its OBD2a -> OBD2b but its not fun.
Old Jun 12, 2009 | 05:29 PM
2drh22's Avatar
I am in the process of doing the exact same swap. I put a blox mani on my gsr but the final lay out should be the same. Buy a 96-98 civic ex or hx manual transmission harness and starting doing some reading.....everything you need to know is in this thread......
https://honda-tech.com/forums/hybrid-engine-swaps-18/%2A-%2A-obd1-b-series-engine-into-obd2a-obd2b-civic-integra-%2A-%2A-1972711/
Old Jun 12, 2009 | 07:25 PM
egb20v's Avatar
https://honda-tech.com/forums/showthread.php?t=1972711
ok cool thanks man.... and just curious, is your gsr obd1 or 2, and which OBD do you plan on running?
Old Jun 14, 2009 | 01:39 PM
2drh22's Avatar
OBD1 using a hondata S100 in a P28 with a jumper harness....
Old Jun 17, 2009 | 07:15 AM
egb20v's Avatar
so on rhd cars is the harness backwards?
Old Jun 17, 2009 | 07:38 AM
egb20v's Avatar
like from ctr swap
Timothy Yhtomit
Feb 26, 2019 02:25 PM
splatterpaintdc
Mar 31, 2010 06:12 PM
import-tooner
Apr 12, 2009 04:41 PM
hmtcrxsir
40
Sep 21, 2007 06:21 PM
99'b16at
Oct 15, 2005 09:27 AM
