Can i get 18PSI out of a 8psi spring w/BC?
Old Jun 1, 2009 | 10:34 AM
Project_EK's Avatar
Default Can i get 18PSI out of a 8psi spring w/BC?
Im going to get tuned next week. I plan on running 18psi max. Can i use a big yellow (8.70psi) spring, how much over spring lbs can i go?
BTW: this is a tial 44mm WG and ill be using a MBC
Old Jun 1, 2009 | 10:52 AM
EARLdaSQUIRREL's Avatar
official honda whore
Default Re: Can i get 18PSI out of a 8psi spring w/BC?
should be able to get close to it
Old Jun 1, 2009 | 01:11 PM
98h22's Avatar
you should be able to.my car has a 5psi spring and im currently running 18psi with my mbc.i always thought you were suppost to use a real weak wastegate spring when using any type of boost controller.
Old Jun 2, 2009 | 05:23 AM
Project_EK's Avatar
bummppp
Old Jun 2, 2009 | 05:57 AM
TheShodan's Avatar
Moderator
Yes. The spring (if it is a TiAL) typically can take 2.5 times its rate (In your case over 20psi) Get to tuning. Good luck.
/thread
Old Jun 2, 2009 | 07:03 AM
TiAL's Avatar
no,
get a 9+psi spring
Old Jun 2, 2009 | 07:12 AM
TheShodan's Avatar
Moderator
Originally Posted by TiAL
no,
get a 9+psi spring
You givin' me a hard time, champ? You wanna take this outside? Huh? Huh? ;-)
I've made 18psi on an 8psi TiAL spring.. so now whatchu gotta say.... HUH? HUH?
Old Jun 2, 2009 | 07:34 AM
TiAL's Avatar
i'd say it would have been made sooner with more power under the curve had you had a stiffer spring in it, and been more consistent ;-)
Old Jun 2, 2009 | 09:33 AM
sp00led's Avatar
I have a .7bar spring in my v44 that makes 13psi on my setup. I've made 29psi on a GM solenoid.
turbo-crx
Apr 1, 2009 11:42 AM
ctownintegra
Jul 9, 2008 02:41 AM
tagperformance
Jun 29, 2007 03:33 PM
RICE POLICE SIP
Sep 26, 2006 07:24 PM
DA-MAX
Mar 3, 2004 12:24 PM
