Name this part game....
Old May 27, 2009 | 12:01 PM
Cortez_h's Avatar
Default Name this part game....
I got a B18 swap for my eg and noticed this on the back of the block. Never seen it before and wanted to know if somebody could inform me in wtf it is.
This is the SS line that comes off the pic above
Also is this some sort of adapter that the oil filter is connected too???
Old May 27, 2009 | 12:04 PM
xwhitchx's Avatar
Default Re: Name this part game....
its a sandwitch adaptor, it for turbo so you dont have to tap your oil pan al so you can use it to hook up an oil presor sensor
Old May 27, 2009 | 12:09 PM
Cortez_h's Avatar
Oh ok. Hmm wonder why the oil pan was tap too Happen to know what the piece next to it is?
Old May 27, 2009 | 12:11 PM
waaBAAH's Avatar
oil pan is tapped into for the oil from the turbine bearings. no pressure is there
Old May 27, 2009 | 12:14 PM
xwhitchx's Avatar
no i dont know what the other part is, i only know what that is becuz i saw them on line yesterday
Old May 27, 2009 | 12:19 PM
shailoche's Avatar
Could be that the original owner tapped the oil pan before deciding to run a sandwhich adapter. Also, I have heard that sandwhich adapters are a weak spot for turbo systems. They are trick but they don't work nearly as well as a plain old hole in the oil pan.
Old May 27, 2009 | 12:21 PM
Cortez_h's Avatar
Somethings making me think this motor isn't stock for some reason. I keep finding new things everyday. Thought the ITR shift linkage was the only surprise I was gonna find.
Old May 27, 2009 | 12:27 PM
Pothole987's Avatar
the other sensor appears to be oil temperature. it has the same look as the temperature sensor underneath the distributor.
Old May 27, 2009 | 12:49 PM
cleansi's Avatar
one is a oil pressure sensor aftermkt) the sandwich plate is for the turbo feed line . the oil pan is for the return line, like the guy said the return has no pressure, the feed does
Old May 27, 2009 | 12:50 PM
jeffsciv23's Avatar
sandwish adapter for oil feed but at the same time the used a block fitting for the oil feed where the oil pressure sender is supposed to be and put the sensor on the filter adapter. im not sure what the hell that other thing is. and the oil pan should be tapped as well for oil return. if you just bought the motor and didnt know it was boosted before i would do a compression test to make sure its still in good shape.
solo2fresh
Mar 2, 2011 04:09 PM
swatteamtimmah
May 7, 2006 04:19 PM
TrueUntilDeath.com
Feb 12, 2005 10:13 PM
JohnShaft
Nov 3, 2001 09:54 AM
Peter K
Aug 29, 2001 09:58 PM
