misfire need help
Old May 17, 2009 | 10:00 AM
ftrms's Avatar
Default misfire need help
My car has had a cel for cylinder misfire in all cylinders, and it bogged and sputtered in low rpms. I changed the plugs/wires, cap and rotor it helped it out a lot, it doesn't sputter or bogg anymore but there is no low end power at all it feels like somethings clogged. It still has cel on, but someone said my cat could be clogged and i know mines bad could that be it or something else? anything helps
Old May 17, 2009 | 10:26 AM
lcsej1's Avatar
Default Re: misfire need help
could be your injectors?
Old May 17, 2009 | 10:30 AM
ftrms's Avatar
is there a special way to clean them? or how do you clean them
Old May 18, 2009 | 05:07 PM
ftrms's Avatar
problem is still happening any ideas?
Old May 18, 2009 | 05:11 PM
R666_EK's Avatar
How's your gas mileage? Is the CEL still on? Try doing more maintenance. Replace fuel filter, pcv, air filter etc...
Old May 18, 2009 | 09:20 PM
ftrms's Avatar
gas mileage sucks from what i can tell, i dont know if this matters but theres no vtec either, you can hear it when its supposed to but theres nothing there..
Old May 18, 2009 | 10:24 PM
R666_EK's Avatar
Could be a bad o2 sensor. I've had pretty bad gas mileage since I swapped my b18c and at first it had some stuttering issues. I've done just about every maintenance thing I can think of, and have so far stopped the stuttering but my fuel economy still suffers. Vtec doesn't have much, if any kick either. So its just a suggestion. The o2 sensors are gonna be the next thing I try.
Old May 19, 2009 | 03:40 PM
ftrms's Avatar
i have to buy a new cat this week and o2 sensor so ill see if thats it
stretchd1
Mar 11, 2011 05:50 PM
EJ8-Yao
Sep 8, 2009 05:42 PM
SpeedoKing
16
Oct 8, 2008 11:26 AM
OhWUNshlude
Nov 29, 2007 09:37 PM
srv3fender
22
Mar 7, 2005 11:27 AM
