Whats wrong with my slave cylinder?!?!
i recently had to change out my slave cylinder it was leaking and h-t said it might of been a ring out of place but it was cheap to replace i jus decided to just go with a new one. today i got a new slave cylinder from autozone the fluid line that connects to the slave cylinder from honda and a bottle of dot 3 brake fluid when i got home replaced everything dumped in the new brake fluid my clutch pledal was still super soft and not stiff like how it use to be anyone know what i am doing wrong and how to fix it? thanks h-t!
Re: Whats wrong with my slave cylinder?!?!
after i took of the old slave cylinder and the line connected to it i pumped the clutch pedal until all the fluid was out of the resivor
Heres a thread to check out, it will go through pretty much all the diagnosing, and will give you a good idea how to bleed a system properly.
https://honda-tech.com/forums/showth...lutch+problems
i was by myself so i filled the reservior then pumped it then closed the bleeding valve what should i do to fix this?
if u have air in your clutch master cylinder you have to bench bleed it get a tub that connect to the opening of where the fluid comes out leading to the clutch master reservoir and pump until you dont see bubbles then install dont let it get too low on fluid
Duck Sauce
04-13-2008 09:30 PM
.water
04-03-2006 07:56 AM
