b18c w/ b16 head vtec issue
Old May 14, 2009 | 11:57 AM
Eg6Matt's Avatar
Default b18c w/ b16 head vtec issue
well ill start off by saying im fairly new to the site. ive been on other honda forums but im finally making the transition to hondatech. so if this thread is in the wrong spot sorry
My issue is ive got a 95 gsr block with a 99 b16 head, and for some reason my vtec isnt working. I just swapped the motor and ive tried everything i know to try and get my vtec to work but nothing so far.
I cleaned the solenoid, checked my wiring at least 10 times, made sure it was properly grounded.
If anyone know anything i can try please lmk
Old May 14, 2009 | 12:01 PM
LA_HONDAS's Avatar
Default Re: b18c w/ b16 head vtec issue
how do know the vtec is not working?
what cams do you have?
Old May 14, 2009 | 12:05 PM
kyden's Avatar
was the head tapped for ls/vtec?
slowturbocx's Avatar
check engine light?
is your computer fried?
what car?
what dizzy?
Old May 14, 2009 | 12:10 PM
Eg6Matt's Avatar
there is no vtec cross over(cant hear or feel it)
gsr cams
nope
Originally Posted by slowturbocx
check engine light?
what car?
what dizzy?
well i would hope my ecu isnt fried
its a 94 civic hatch
and im not sure on the dizzy, some obd1 one
Old May 14, 2009 | 12:21 PM
LA_HONDAS's Avatar
is your vtec pressure switch hooked up
was the car up to temp when you drove it
your ecu or vtec solenoid could be fried
Old May 14, 2009 | 12:39 PM
Eg6Matt's Avatar
yup, my pressure switch it hooked up.
the car was running right between 1/4 and 1/2 on the temp gauge, but the radiator fan comes on so im assuming that its all the way warmed up and the coolant is running in the open loop.
is there any way to check if the ecu or solenoid are fried?
Old May 14, 2009 | 12:43 PM
kyden's Avatar
is your oil pan dented?
Old May 14, 2009 | 12:45 PM
Eg6Matt's Avatar
nope.
Old May 14, 2009 | 12:52 PM
philafelman's Avatar
isnt there an o-ring under the center cam cap...might check it out....also, could you manually jump the solenoid with a 12v power source to see if it activates.
Old May 14, 2009 | 12:56 PM
LA_HONDAS's Avatar
you can use a test light on the ecu hook it up to pin a4 and take it round the block and it should light up where vtec cross over
siregcivic
Dec 9, 2009 02:27 AM
volcom_7_1
Jul 8, 2009 06:34 AM
BIG T
Jul 21, 2007 08:28 PM
insaneshoota
Dec 15, 2006 11:17 PM
jdmsijdm
Jul 12, 2004 11:51 AM
