should this be clean??
Old May 5, 2009 | 08:12 AM
nateb22's Avatar
Default should this be clean??
it is actually way dirtier than it looks.
Old May 5, 2009 | 08:15 AM
RACEPAK's Avatar
Default Re: should this be clean??
its called a throttle,
if you have problams then yes,
remove the throttle from the intake manifold and clean all the dirt with a carb cleaner.
Old May 5, 2009 | 08:18 AM
B18C5-EH2's Avatar
Former Moderator
Loved
There will usually be a line of grime there, and unless your gas pdeal sticks I'd leave it alone. some people go gung-ho and spray too much carb cleaner in there and end up screwing up a MAP/TPS/IAT sensor when trying to clean out the throttle body.
Are you asking out of curiousity,or are you having an issue with the gas pedal/throttle?
Old May 5, 2009 | 08:19 AM
1LowSol's Avatar
+1
Old May 5, 2009 | 08:21 AM
nateb22's Avatar
it is in a 94 sol si and yes the throttle sticks sometimes.
Old May 5, 2009 | 08:27 AM
B18C5-EH2's Avatar
Former Moderator
Loved
BTW:
You could always take a clean rag or spray a LIGHT mist of carb/choke cleaner on a rag and wipe that area out while holding the butterfly open - ENGINE OFF of course.
I'm just not a fan of the "spray carb cleaner in and hold the throttle open" method that so many people try.
Old May 5, 2009 | 08:29 AM
nateb22's Avatar
nor am i, thats why im doin a write up.
Old May 5, 2009 | 08:38 AM
kp's Avatar
kp
You're doing a write up of how to clean a tb? Lubricating the return spring can also help a sticky throttle.
Bakeoff's Avatar
Don't use carb cleaner... Use intake cleaner. Its meant to be safe for sensors on fuel injected cars and its the same price.
If it still sticks after you clean it, you can also adjust the throttle stop screw on the throttlebody.
Old May 5, 2009 | 08:41 AM
nateb22's Avatar
for myself
1 more ?
is a d16z6 a decent engine?
Old May 5, 2009 | 09:08 AM
judgement_jdm's Avatar
If ur bored u should clean it..
Old May 5, 2009 | 09:12 AM
nateb22's Avatar
i am bored, but i have looked everywhere for a diagram of the throttle body and how to take it apart to clean, but i have found nothing. any help???
i just want to know what im doing before i do it. i dont wanna fauck things up.
Old May 5, 2009 | 09:32 AM
FearTheH's Avatar
take the throttle body off the intake manifold and clean the butterfly and inside the throttle body, like B18C5 said, dont use too much, you'll screw your sensors for sure. you dont need to completely disassemble the throttle body. if you really want to disassemble if, but a new one first.
Old May 5, 2009 | 09:46 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Do not disassemble the throttle body.
I wouldn't even bother taking the throttle body off the intake manifold - just open the throttle plate and wipe the area out with a slightly damp (with carb/choke cleaner) rag and then wipe clean with a dry, lint-free rag.
Old May 5, 2009 | 12:06 PM
RACEPAK's Avatar
just for the record, most of todays carb sprays are sensor friendly.
Old May 5, 2009 | 12:13 PM
EG6KILIN's Avatar
if you take out the throttle body out make sure you get. Another gasket for it because the old one might not be good anymore or just rip when you take it out.
Old May 5, 2009 | 01:01 PM
thumper64's Avatar
Just FYI, the Majestic Honda parts site has throttle body gaskets for like $3 for the Z6.
My throttle stuck on a road trip I went on the other day. When I'd mash the gas my engine would idle around 2000 rpms. Just as a quick fix, I put a little motor oil on the spring for the butterfly valve and it fixed it. You could try cleaning your spring, that at least wouldn't hurt anything. I know I'll have to once the oil collects more dirt.
JDM_EK_JOE
Mar 3, 2012 07:07 PM
BLKFLSH
Sep 22, 2009 05:49 PM
a_wishbone
Jun 25, 2008 08:26 PM
Al-sonic
Jan 11, 2007 05:52 PM
SEVENSIX
Jul 24, 2002 04:16 PM
