how to clean throttle body and intake manifold
Re: how to clean throttle body and intake manifold
remove the tb from the IM, remove IM from the head. use carb, throttle body cleaner, or brake cleaner to hand clean the throttle body with a rag, paying close attention to throttle butterfly edges. if you have access to a solvent tank you can soak your IM (after removing sensors) and clean in the tank with a brush. after you're done in the solvent (or if you dont have access to one) use carb/tb/brake cleaner to remove solvent/carbon goo. I would advise not using a rag to clean the runners in case a fiber gets snagged/loose inside. use paper/shop towels instead. be sure to clean the mating surfaces and replace TB/IM gaskets- also a good time to pick up a phenolic IM gasket to gain a pony or two.
If you dont want to remove either component from the engine you can still hand clean the TB with the cleaners listed. if your engine is OBDI, you can start your car and spray the TB cleaner directly into the TB while throttling the car with your other hand. If you have an OBDII car i would advise against this step since you may set a CEL. you can also drip some top engine cleaner into a vacuum source on your IM to clean your intake valves and part of your IM runners.
cheers!
cheers!
other than that, it worked GREAT! lol.
cheers!
cheers!
Hi, I just got done cleaning my throttle body for the first time today. My car 1997 d16y7 was off and I sprayed it in the butterfly valve with a rag and wiped out all the gunk. When I tried to turn my car on, it didn't start immediately and the idle sounds like it's about to stall. And my CEL is on. What should I do now?
Civicr2gs5
15
11-25-2004 08:13 PM
speedehatch
01-19-2004 02:28 PM
