Broken ect sending unit sensor.
That's right, it's in an obd1 b16a.
It's not the two wire ect sensor that reports to the computer, it's the single wire one for the temp sending unit on the cluster.
I was trying to remove it from the head while the engine was warm like a dumbass and the sensor broke in half leaving the other half of the sensor (threaded part) flush in the head.
Anyone have any idea on how to remove this?
The sensor itself is hollow with a plastic sheath around a spring, both of which have been removed so that can give me some help...
Re: Broken ect sending unit sensor.
You might want to try using a reverse threaded extractor tool like the one shown in the picture. This tool can be purchased from your local hardware store.
this is off the topic. i have code 86 ect cel light on. changed the temp sensor and light came back on. what sensor is the ect sending unti like as its location relevant to temp. sensor. btw i have a b18c if it makes any diff. its obd2b
check the resistance of the new sensor at cold and hot to make sure it's sending correct signals back to the pcm. I believe it uses a 5 volt reference wire and a return wire to the computer...grab a service manual for procedure, I believe all b series are the same.
