how do i clean the throttle body with the carb cleaner
can i take out the map sensors and clean them too or clean the area under the map sensors so it can stop any map sensor clog
Re: how do i clean the throttle body with the carb cleaner (Al-sonic)
ya you can take the map sensor off and spray in the hole.. blow it out before you put back.. break the screw with a needle nose visegrip they are easy to strip. don;t use carb cleaner.. use throttle body cleaner.. if it was the same it would be called carb/throttle body cleaner!
Re: how do i clean the throttle body with the carb cleaner (gezzuzz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gezzuzz »</TD></TR><TR><TD CLASS="quote">ya you can take the map sensor off and spray in the hole.. blow it out before you put back.. break the screw with a needle nose visegrip they are easy to strip. don;t use carb cleaner.. use throttle body cleaner.. if it was the same it would be called carb/throttle body cleaner!</TD></TR></TABLE>
might also be an idea to remove the valve cover to intake pipe to stop this oil crap getting in your throttle?
thanks but there is also a plug behind the throttle body should i do that one as well and what is that plug called
first spray the t/b cleaner in the throttle, get an old toothbrush, open the throttle and scrub inside and on the throttle plate aswell, then once done that, start the car in a well ventilated area, and spray the rest of the t/b cleaner in while running and opening the throttle just a little
black0hatch
12-03-2010 04:17 PM
a_wishbone
06-25-2008 08:26 PM
asubennett
09-30-2003 03:19 PM
