Tourque Mounts
Old Apr 11, 2009 | 10:23 AM
Ej8_KiD's Avatar
Default Tourque Mounts
So i've been thinking about some cars i've seen around with no tourque mounts , and im planning on buying some hasport's or innovative mounts , is it safe to take them out?
Old Apr 11, 2009 | 11:11 AM
mini-meEj1's Avatar
Default Re: Tourque Mounts
If you wanna shear your bolts off. I knew a guy who ran no tq mounts and shifted 9k all day and ended up snapping the trans bolts clear off ... I would run em
Old Apr 12, 2009 | 07:05 PM
Ej8_KiD's Avatar
Even with hasport or innovative engine mounts?
Old Apr 12, 2009 | 07:17 PM
ixoiiiiviviiivi's Avatar
they're there for a reason dude. i've seen the motor jump and pop a pimple into the hood because they didnt run torque mounts. but its up to you
Old Apr 12, 2009 | 07:52 PM
Ej8_KiD's Avatar
I know that , but im wondering how is it that theres a lot of car's out there without them , dont they drive their cars or what
Old Apr 12, 2009 | 07:58 PM
Murk 'EM's Avatar
i have avid full race mounts (black inserts) and im not running torque mounts cause the mounts are strong/stiff enough that the torque mounts really dont do anything.. it all depends on your set up if your just getting street/strip mounts keep the torque mounts there but if your gettine straight strip mounts you dont really need them
Old Apr 12, 2009 | 08:02 PM
tdbhonda's Avatar
this happened to 4 of my friends i can think of and myself
+ i blew my Left upper motor mount twice before putting them on
i put my right torque mount on and it made a world of difference, go figure lol
Old Apr 12, 2009 | 08:05 PM
MonkeyMagic's Avatar
OMG DANNGGG
did he really shift 9k all day?!?! musta been a spoon motor...
...that or they improperly torqued the tranny bolts. idiot.
yeah there is a few reasons behind this. one is they are much stiffer. the 3 hasport mounts are 30000% stiffer than all 5 factory mounts.
two is engine location... alot of aftermarket kits put the engine in a slightly different location than the factory would've.. so they won't line up.
either way with aftermarket mounts... ditch'em
Old Apr 13, 2009 | 08:49 AM
Ej8_KiD's Avatar
Originally Posted by MonkeyMagic
OMG DANNGGG
Thats what i was thinking , thank you for the straight answer
Old Apr 13, 2009 | 11:02 AM
Hasport's Avatar
the torque mounts are there for a reason
a. to keep the engine from torquing (obviously)
b. to keep the engine from entering the passenger compartment in the event of a crash
you should always run torque mounts regarless if you have aftermarket mounts or not
Old Apr 13, 2009 | 12:52 PM
dividedas1's Avatar
best answer
Old Apr 13, 2009 | 01:31 PM
shake-zula's Avatar
i had innovative mounts in my last swap and no torque mounts caused i believe my friend it wasnt going to be bad....and i ended up snapping the bracket off the motor on the driver side...it was smoking anyways but still always use your torque mounts...now i got b20 and torque mounts were the first to back on along with inserts.....
Old Apr 14, 2009 | 08:07 AM
Ej8_KiD's Avatar
Im just gonna keep them when i buy my engine mounts , i was asking cause the bay looks soo good without them
B_Swapped93
Oct 28, 2013 06:22 AM
murphy95si
Jun 8, 2013 04:51 PM
highroller54
Jan 20, 2010 02:02 PM
WalkerGSR1
Jan 6, 2007 06:20 AM
crxsiperf
Apr 8, 2006 08:01 PM
