rounded bolt
Old Mar 17, 2009 | 02:10 PM
ryanevansoh's Avatar
Default rounded bolt
ok i was trying to pull the head of a b18a at the junkyard and one of bolts that holds the head on is rounded off. i tried to get it off, but it did nothing. my question is how am i supposed to get it off? any suggestions or help is appreciated
Old Mar 17, 2009 | 02:17 PM
spens 91 Ef's Avatar
Default Re: rounded bolt
try some big pliers, or put the smallest sized socket thatll fit on the bolt push down as hard as you can and turn
Old Mar 17, 2009 | 03:40 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Are you using a six point socket or is it twelve?
Old Mar 17, 2009 | 03:53 PM
i tried to use a 12 becuase thats all i had but it stripped it a bit more. im gonna try to file it down now and try to get it off with a 13mm
Old Mar 17, 2009 | 04:07 PM
4drEF's Avatar
Keyboard Humorist
Do you have an old 12 point 13mm or a non-metric around that size that you don't care for?
You can sometimes reshape the bolt head by hammering the smaller socket onto it.
Old Mar 17, 2009 | 04:09 PM
gator88's Avatar
try a 6 point first on a half inch extension that hangs up to where you can smack it good with a hammer and fully seat it and make it snug, then ratchet that bitch out. trying to file a bolt into a smaller size will be a pain in the *** and just put shavings in the head.
Old Mar 17, 2009 | 04:17 PM
DazeMS's Avatar
word... Just hammer the **** out of a smaller socket onto the head of it.. YOU WILL get it.. also, what helps is try tightening back up the other bolts to help get the stress off that one stuck bolt..
this has never failed me..
Old Mar 17, 2009 | 04:50 PM
88DXCRX's Avatar
Snap-on as well as others make special sockets
called "twist sockets" that would probably work for you..
They have a spiral design which grips tighter
as it is turned counter-clockwise.
Snap-on Blue-point TFSY14 is the 14mm one..
Old Mar 17, 2009 | 07:47 PM
bEEsKnEEs's Avatar
88dxcrx is on it! I got a set of those but they were craftsman. It came in a set of 4 or 5 and they were prolly pretty cheap at sears, well i'm assuming that because my aunt got them for me last christmas... Either way a total life saver.
Also there is a thing called a 'gator' and its a socket with a bunch of pins in it that are spring loaded that you can push over a fastener and it will grab it with the pins. I dont think it was that great of a tool, especially after getting the twist sockets, but its at wal-mart and better than nothing...
Old Mar 17, 2009 | 08:05 PM
thanks for all the help guys! looks like ill be getting that bolt off now
tensaiwung
27
Mar 28, 2012 10:02 AM
Zinch
Mar 17, 2007 06:26 PM
spidermancivic
Oct 3, 2006 09:41 PM
Btothe3rdDegree
20
Jan 23, 2005 01:36 PM
gsrmike
Apr 11, 2004 12:06 PM
