Greddy Type S spring mod
Has anyone done this? I've had some concern for instance when going up a hill and the car builds a little bit of boost to get up it, then at the top when i let off a little i get the "sput sput sput" which to me sounds like compressor surge. I searched google and found that EVO owners are removing the smaller of the two springs inside the Greddy Type S. This allows the BOV to open under earlier vacuum, like -16 instead of -25 (or -21 can't remember) but still holds 24psi of boost. I'm only running 8psi so i went ahead and tried it and seems to work perfect for me. No more sputtering, it actually opens and doesnt allow the compressor surge. Removing the smaller spring just allows it to open easier. Now this is only the case if you are NOT using the lower nipple on the BOV. I searched Honda-tech but found nothing on this topic.
http://www.evomoto.com/tech_info.php?tech_id=7
bubskie
Jan 21, 2011 03:27 PM
