Greddy Type S spring mod
Old Mar 14, 2009 | 05:29 AM
BDogggUT34's Avatar
Default Greddy Type S spring mod
Has anyone done this? I've had some concern for instance when going up a hill and the car builds a little bit of boost to get up it, then at the top when i let off a little i get the "sput sput sput" which to me sounds like compressor surge. I searched google and found that EVO owners are removing the smaller of the two springs inside the Greddy Type S. This allows the BOV to open under earlier vacuum, like -16 instead of -25 (or -21 can't remember) but still holds 24psi of boost. I'm only running 8psi so i went ahead and tried it and seems to work perfect for me. No more sputtering, it actually opens and doesnt allow the compressor surge. Removing the smaller spring just allows it to open easier. Now this is only the case if you are NOT using the lower nipple on the BOV. I searched Honda-tech but found nothing on this topic.
http://www.evomoto.com/tech_info.php?tech_id=7
Old Mar 14, 2009 | 07:16 AM
turbo boost's Avatar
Default Re: Greddy Type S spring mod
what is the smaller lower nipple acually for??
Old Mar 14, 2009 | 08:47 AM
BDogggUT34's Avatar
I believe it helps the bov open after you let off the throttle. That is if its hooked up to a source pressurized source. In honda applications, most people just let that go and not connect it to anything.
Old Mar 14, 2009 | 11:23 AM
LShatchie's Avatar
yes works great
Old Mar 14, 2009 | 08:58 PM
da_dude's Avatar
I did the same with the greddy rs I had. It will surge badly if I let off on part throttle. Took the inner spring out and work flawlessly.
bubskie
Jan 21, 2011 03:27 PM
bluels-t
Oct 20, 2004 07:29 AM
94dxt
Jun 16, 2003 09:01 PM
D-Man
Feb 12, 2002 03:30 PM
