Jrsc compatibility question
Old Mar 13, 2009 | 02:35 PM
jpo20's Avatar
Default Jrsc compatibility question
Pretty sure it is compatible, but I want to be absolutely sure before bidding...is this JRSC kit compatible with my y8?
http://cgi.ebay.com/ebaymotors/ws/eB...m=110361623032
Also whats not on the kit that I would need...fuel pump?Heard bad things about the fmu too, what would u guys suggest instead? Will probably run it at 8 psi, would stock internals handle it or would I need to upgrade? What about for 10 psi?
Sorry for all the questions, this is my first FI car.
Old Mar 13, 2009 | 02:43 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Jrsc
need to be a little more non vague on the title. (ill fix that when i move it for you)
im not sure if it will fir your y8 or not, but if the ports and bolts line up i would think it should.
as for the fuel pump, remember your stocker wasnt made to make the power the jrsc will allow youto. the fuel pump is a cheap investment.
FMU? ah no. ancient tech.
get a chipped ecu, although you will have to downgrade to obd1 (assuming you have a 96 or newer car with the y8) or get an ems and have a pro tune it.
hondata has a few jrsc maps that come along with the s manager.
moving to fi you will get better answers there.
Old Mar 15, 2009 | 12:39 AM
jpo20's Avatar
Default Re: Jrsc compatibility question
anyone?
protopro88
Apr 7, 2011 09:14 PM
Badass240SX
16
Aug 21, 2005 05:47 PM
jbell
Dec 4, 2004 04:53 PM
Tru Dynamix
Apr 30, 2003 10:33 AM
Super Cat
May 1, 2002 02:11 PM
