rod bearing colors??
Old Aug 9, 2002 | 07:47 PM
cbmlsvteg's Avatar
Default rod bearing colors??
i need to replace new rod bearings on an ls, but i am not sure which bearings to use. To my understanding the bearings are color coded on the edge of each bearing. The color code on the bearings that i'm replacing are faded so i am not sure which ones to get. I know there are numbers stamped to the crankshaft and the rods to help determine the correct color. The number 2 is stamped on a pair of rods and the number 3 is stamped on the other pair. On the left side of each cranshaft journal there is a letter B. On the right side of the cranshaft rod journals are the numbers 2,2,4,3. Does any1 know how i can use this two get the right color coded bearings? One more thing....i took the rods to the machine shop to be modifed a bit, and the machinist took the tags off that labeled each rod to its corresponding cylinder. Is there a way to measure something on the crank or rod bore to determine what cylinder it came from??? HELP!!!
Old Aug 9, 2002 | 09:21 PM
taylor_durdan's Avatar
Default Re: rod bearing colors?? (cbmlsvteg)
there will be 5 letters engraved in the bottom of your block close to the rear main seal. these are the main bearing sizes (part 1)
for example:
BBBAB
on the crank, there will be 5 NUMBERS, one for each main journal. these are also for the braing sizes (part 2)
take the letter for journal #5 (rear main one) and match it up to the first letter on the block. go from there
rods:
the rods will have number on them (typically 2's or 3's). match these up with the LETTERS on the crank shaft. match up your rods. dont worry where they WERE, but just once you match them up where theyre GOING, dont mix them up.
anymore questions, give us a call at our shop. see sig for #
Old Aug 10, 2002 | 01:13 AM
cbmlsvteg's Avatar
Default Re: rod bearing colors?? (Taylor)
The only letter i see next to every rod journal is the letter B. The rods are stamped either the number 2 or 3. So the color code would be B2 and B3....or as my haynes manual states yellow and green.
Are you saying once i match up the rod with the crank letters and get the right bearing code, it would no longer matter what cylinder i put the matched rods and bearings back in? That's the one thing i'm still not sure about. The machinist pulled the tags i labeled off and now i don't know what cylinder it came from.
Old Aug 10, 2002 | 11:22 AM
cbmlsvteg's Avatar
Old Aug 10, 2002 | 12:02 PM
Leimokei's Avatar
New User
http://www.team-integra.net/sections...?ArticleID=405
courtesy from Tuan...@ team-integra.net
Old Aug 12, 2002 | 02:32 PM
cbmlsvteg's Avatar
Default Re: rod bearing colors?? (Leimokei)
I just want to thank you for your post...i ordered the bearings a couple of days ago from the dealer and they had orderd the wrong parts! I told the guy that i wanted rod bearings but instead he ordered the main bearings instead. Anyways.....the parts listed on that link you posted helped me distinguish the correct part numbers. I called the dealer and they indead messed up my order. Thanks again for the post. It saved me time that could have been wasted!
Old Aug 12, 2002 | 05:24 PM
sjk's Avatar
sjk
I have a concern as to what the machine shop actualy did to the rods?If any machining was done to the big end of the rod the the numbering system is not going to be correct.Make shure of this,if nothing was do,the info sent to you is correct.
Old Aug 13, 2002 | 12:04 PM
Leimokei's Avatar
New User
ur welcome...
russ.shafer
Nov 6, 2011 06:46 PM
ilikericedotcom
Mar 21, 2011 08:00 AM
2ndgentegracer
Aug 14, 2004 11:19 AM
Brian_92GSR
Apr 2, 2002 01:53 PM
CivicNewbie
Jan 24, 2002 10:42 AM
