starter broken?
Old Jan 18, 2009 | 10:04 AM
sd_ej1's Avatar
Icon6 starter broken?
i have a 94 gsr motor in my civic.
the car has been sitting for awhile and hasn't started
since my cousins boy friend messed it up
i juss put in new spark plugs, and my battery is dead,
but i tryed jump starting it and nothing.
the starter seems to be broken, its making a clicking noise when the car starts to crank
can someone help me confirm that the starter is the problem
Old Jan 18, 2009 | 10:10 AM
z6hatchboy's Avatar
Default Re: starter broken?
yeah, its probably the bushings inside the starter. Try bumping it with a hammer and then try turning the key
Old Jan 18, 2009 | 12:57 PM
sd_ej1's Avatar
cool, is there a link the teaches you how to rebuild a starter?
someone was tellin me about that too
Old Jan 18, 2009 | 04:27 PM
1LowSol's Avatar
I have a starter if you'd like to purchase it or, You can try hitting it with a hammer, And have you made sure the battery isn't dead?
Old Jan 19, 2009 | 09:42 AM
sd_ej1's Avatar
ohh i jusT bought a new battery...
btw do you think i can get a refund? cuzz i think i still have a warranty
but after i put the new battery in , we tried starting it.
it just cranks real hard but still nothing...
any ideas?
Old Jan 19, 2009 | 09:46 AM
Kristin.'s Avatar
When you turn the key, does it make a ticking sound? If so, that's the starter trying to engage. Try using the old hammer trick. If that doesn't work, the starter could possibly be going bad and isn't strong enough to crank the motor anymore. Taking it out and testing it on a battery to see if it'll spin, is a pointless test, just so you know... and don't waste your time doing it. The battery will spin the starter whether it's good or bad. You can't tell by that diagnostic if the starter is strong enough to crank the motor. Just keep that in mind. It could be the bushings, but rebuilding a starter nowadays is damn near pointless when you can go pick one up from a junkyard or just buy a new one.
Old Jan 19, 2009 | 12:14 PM
sd_ej1's Avatar
There was a ticking noise until i bought the new battery.
but now the new battery is in
it juss cranks but just wont start..
i tried the hammer trick but nothing
do u think it could be a fuse?
Old Jan 19, 2009 | 12:23 PM
instructor74's Avatar
Tapping the starter with a hammer would only work if the starter isn't spinning or not contacting the flywheel. If the engine is turnng over and just not starting then the problem is something else, no spark, no fuel, or a timing issue.
Old Jan 19, 2009 | 04:51 PM
sd_ej1's Avatar
so a bad fuse could also be a problem?
Old Jan 19, 2009 | 05:23 PM
slimjimming6688's Avatar
do you geare the fuel pump come on when you swich the key to the on position?, check your pgmfi fuse under the hood
Old Jan 19, 2009 | 05:24 PM
make sure theres fuel and spark, use a spark tester.
Old Jan 21, 2009 | 06:08 PM
sd_ej1's Avatar
i checked my car today, and sadly it still hasn't started...
how do i check if its the fuel pump?
Old Jan 21, 2009 | 06:11 PM
-=ZAK=-'s Avatar
try tappin the starter with a hammer
Old Jan 21, 2009 | 06:44 PM
sd_ej1's Avatar
i tried that, no luck...
Old Jan 24, 2009 | 05:36 PM
sd_ej1's Avatar
so any ideas???
Old Jan 24, 2009 | 05:41 PM
green99civic's Avatar
fuel pump connect a pressure gauge to the the fuel filter research the pressure for your exact system. That probably would be the best way to test it or you can take the pump out which is underneath your back seat
Old Jan 24, 2009 | 06:21 PM
jdmdc2boi12's Avatar
dude, my best suggestion is to change ur starter... take ur old one out and bring it to kragen and trade ur old one to new for cheaper price..
Mike518
Aug 29, 2012 11:29 AM
serr38
Jan 15, 2010 11:01 AM
itsLOUiSduh
11
Apr 22, 2009 06:51 PM
Integra_drk
Dec 27, 2006 10:19 AM
SlowB16
Oct 7, 2002 12:28 AM
