Eagle Rods, what bearings to use?
i'm building a B20/VTEC for a buddy of mine. i'm using OEM main bearings, but i dont kno if i can use OEM rod bearings w/ the Eagles? any help would be appriciated
Oem bearings work wonderfull, I have Eagle rods in my LS, but you need to be sure to get the correct bearings, I dont know about the B20, but on a B18b, the stock rods are number coded 1-4, and the crank is letter coded, you match these up to get the color code for the bearings. The eagle rods should be a honda factory rod code 3, well, at least on a B18b, call Eagle and talk to a tech to be sure.
I'm certain you'll be happy with the rods though, my setup revs to 9700 a lil more than I should with no problems to date.
civicguy
Mar 29, 2002 04:56 AM
