In need of some info on my harness
Old Jan 6, 2009 | 05:20 PM
#1 luder's Avatar
Default In need of some info on my harness
Hopefully within the next month I plan on swapping my H23 with a H22a from hmotors. Now I'm all set on swapping motors, but I'm not that good when it comes to wiring up VTEC. The h22 came with a jdm ecu and harness, but I'm going to use a OEM ecu.
Will I run into any problems if I use the jdm harness with an oem ecu?
If I use an oem harness will I just be able to hook everything up with out having to worry about seperetely wiring the VTEC.
Also if there is any other issues I'll probably run into, please warn me.
Thanks.
Old Jan 6, 2009 | 05:27 PM
boostin99ek9's Avatar
Default Re: In need of some info on my harness
I would use your stock harness thats in the car the ECU you recieve with the swap and buy this http://rywire.com/store/9295-prelude...b4516f0370a1c3 and it will solve all your problems
Old Jan 6, 2009 | 05:35 PM
#1 luder's Avatar
OK, so with that I can still use my H23 harness and that rywire hooks straight to the h22 ecu?
Old Jan 6, 2009 | 06:05 PM
Correct!
Old Jan 6, 2009 | 06:13 PM
#1 luder's Avatar
Alright thanks. For some reason when it comes to the harness my mind goes blank.
Tipsy86
Jan 8, 2015 07:22 PM
StockDC2
Jan 6, 2015 08:37 AM
UniqueX707
Nov 24, 2014 11:33 AM
boosted_teg93
Oct 24, 2004 06:54 PM
humtake
May 20, 2003 04:46 AM
