Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Honda Prelude (https://honda-tech.com/forums/honda-prelude-4/)
-   -   In need of some info on my harness (https://honda-tech.com/forums/honda-prelude-4/need-some-info-my-harness-2467524/)
#1 luder 01-06-2009 05:20 PM
Hopefully within the next month I plan on swapping my H23 with a H22a from hmotors. Now I'm all set on swapping motors, but I'm not that good when it comes to wiring up VTEC. The h22 came with a jdm ecu and harness, but I'm going to use a OEM ecu.
Will I run into any problems if I use the jdm harness with an oem ecu?
If I use an oem harness will I just be able to hook everything up with out having to worry about seperetely wiring the VTEC.
Also if there is any other issues I'll probably run into, please warn me.
Thanks.
boostin99ek9 01-06-2009 05:27 PM
Re: In need of some info on my harness
I would use your stock harness thats in the car the ECU you recieve with the swap and buy this http://rywire.com/store/9295-prelude...b4516f0370a1c3 and it will solve all your problems:thumbup:
#1 luder 01-06-2009 05:35 PM
OK, so with that I can still use my H23 harness and that rywire hooks straight to the h22 ecu?
boostin99ek9 01-06-2009 06:05 PM
Correct! :thumbup:
#1 luder 01-06-2009 06:13 PM
Alright thanks. For some reason when it comes to the harness my mind goes blank.
