Shift linkage removal
Old Jan 6, 2009 | 01:44 PM
spens 91 Ef's Avatar
Icon2 Shift linkage removal
Ok im im trying to remove my shift linkage closet to my tranny i got the cover off but im havin troubles getting the pin out anbody have some tips i tried a screwdriver and a mallet and a aligning punch and still wont come out
Old Jan 6, 2009 | 02:38 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: Shift linkage removal
8mm punch and a hammer, or a pneumatic air hammer.
seriously.. stop what you are working on, go to sears, and buy a 8mm punch. its the only way.
There is some bolt you can easily remove from the engine bay that is the right size as well, but then you will be hammering on a bolt that goes to something. and i cant remember what it is.
just buy an 8mm punch.
Old Jan 6, 2009 | 02:42 PM
D16SiHatch's Avatar
I just put this little image together yesterday for someone else having bitch pin issues over at hondaswap. technically that pin is referred to as a wrist pin, but whatev :p
give this a try:
Use a small c-clamp and placed it around the bitch pin. then on one side use a socket that is deep enough to contain the entire wrist pin once its pushed out. on the other side use a square drill bit piece (or another bit that the business end fits within the pin). setup should look like this.
then start turning it by hand till you cant twist anymore. grab some vice grips and use them to turn the handle on the vice. slowly the pin will start to push out and eventually fall out into the socket. all without bashing on things with a hammer
ninja edit: ^the bolt you're thinking of is the a/c compressor bolt.
Old Jan 6, 2009 | 03:03 PM
specialized108's Avatar
^ this is quite a good idea, good tip. may try it myself
Old Jan 6, 2009 | 06:46 PM
EJ1_Sleeper's Avatar
holy crap thats ingenious! i need to try that next time im yankin off the shift linkage. need to find that type of bit now.
btw the pin is called a Spring form pin.
Old Jan 6, 2009 | 06:48 PM
jdmtrdriderpr's Avatar
New User
8mm punch and a hammer is fast and simple!!
Old Jan 6, 2009 | 08:44 PM
schock3's Avatar
Old Jan 6, 2009 | 10:42 PM
schueytenten's Avatar
X2
Its so easy with a punch and a hammer. My only advice is to buy a few extra with your next Majestic order cuz they always fly away never to be seen again!
Old Jan 6, 2009 | 10:48 PM
Singlecam4dr's Avatar
^^ we've all been there. and i like both ideas but i use a hammer n punch
Old Jan 6, 2009 | 11:28 PM
rupensane's Avatar
i modified mine to use a bolt....no more bitch pin for me!
Old Jan 7, 2009 | 10:08 AM
i couldnt find a 8mm punch they didnt have any metric punches so i got 1/2 and it fits but it still doesnt come out so im gonna try some wd 40
Old Jan 7, 2009 | 12:18 PM
sanimalp's Avatar
$cat /dev/urandom
half inch is too big.. 5/16 is what you should have bought..
Old Jan 7, 2009 | 03:37 PM
alrite ill try that
Old Jan 8, 2009 | 01:48 PM
you diagram thing doesnt work to well the thing were the socket sits is round so it doesnt sit ther to well and when your tighting the clamp the drill bit just eventualy some how finds its way off the clamp
Old Jan 8, 2009 | 02:20 PM
sanimalp's Avatar
$cat /dev/urandom
the only one of those i have seen work had the "drill bit" portion of the device welded to the pad of the clamp.
Old Jan 8, 2009 | 02:23 PM
shaggyeg6si's Avatar
The hammer doesn't work so well if it's a 5lb machinists hammer and you have little to no room under your car. Haven't seen a bitch pin post in a while. I think I may try the c-clamp next time around.
Old Jan 8, 2009 | 02:39 PM
sanimalp's Avatar
$cat /dev/urandom
you should buy a nice light 1/4lb ball peen hammer. or better yet, an air compressor and an air hammer..
Old Jan 8, 2009 | 02:46 PM
i was using a light rubber mallet before
Old Jan 8, 2009 | 04:40 PM
D16SiHatch's Avatar
sure it falls off on occassion but i've used this method atleast 3 seperate times and it doesn't take but a few mins to get the pin out.
Old Jan 8, 2009 | 07:14 PM
sorry dude i had a extra hand holding it, it even put dents in my craftsman c clamp
Corksil
12
Dec 29, 2009 10:14 PM
z6hatchboy
16
Aug 6, 2009 07:59 AM
say_xiong
Sep 21, 2006 11:34 PM
BigDawwg6969
Aug 16, 2005 09:59 AM
immortal
Feb 16, 2002 08:27 PM
