shift linkage pin thing?
Get a bigger hammer. I've found that a 1/4 inch craftsman socket extension fits quite nicely all the way through the hole. You just have to keep pounding.
thanks for the input everyone.. it seems there's a screwdriver 'bit' stuck the fk in it now.. doh
The trans is off and the block is going down south with 5 other blocks to get a little this, a little that on em.. Immy should post pics of what it looks like now lol, but we'll get it off.. time for some sleep
When I took my motor out several weeks ago, I spent half a day working on a couple minor problems like this. I never could get that pin out and I ended up taking the shift linkage off where it connects to the shifter. Then I had to worry about a big long rod sticking out of the tranny as it was lowered from the car.
I had a similar problem. I was beating at it and it just wasnt enough. as stupid as it sounds jack the car up as far as you can so u get a bigger swing on the hammer. just that much more might help. i was using a air dremel tool too, DO NOT use it, there's no way in hell to get all of the pin out of there and the metal shavings suck getting all over the place (ie. in my eye).
z6hatchboy
16
Aug 6, 2009 07:59 AM
ALLMOTOR CRX
11
Mar 29, 2007 07:34 AM
