Replaced knock sensor
Old Dec 30, 2008 | 07:43 PM
SpoonFedEj8's Avatar
Default Replaced knock sensor
Do i have to reflash my timing after I replaced it?
Old Dec 30, 2008 | 10:00 PM
Default Re: Replaced knock sensor
Bump, please help any advice would be great.
Old Dec 31, 2008 | 09:54 AM
anyone?
Old Dec 31, 2008 | 10:46 AM
nub's Avatar
nub
Reflash your timming? Not sure what you ment but you should clear the code after you replace the KS
Old Dec 31, 2008 | 12:56 PM
I meant to say adjust my timing. I did reset the ecu, but now it feels as though my timing is off.
Old Dec 31, 2008 | 01:31 PM
nub's Avatar
nub
It doesn't hurt to check it but a bad knock sensor wont loosen the hold down bolts and rotate the distributor. I'm not trying to be an *** but if your timming is off now it was off before.
Old Dec 31, 2008 | 11:30 PM
ohh, i wasnt taking it as being an ***. See I broke the knock sensor when installing a intake manifold. Then replaced it and when I started it up the car was not running right at all. Real rough at idle and it sounds as though the timing might be off. I'm going to check it tomorrow and get back to this post. I appreciate all of your help.
Old Jan 1, 2009 | 03:15 AM
So I'm sitting here looking a the motor and fuel was leaking from my injector that fires to cylinder 1. Pulled the fuel rail off and the top o-ring is torn a little. Would this injector leaking cause my motor to run rough and like ****? Ill let you know how this one goes as well, Im assuming this is probably my problem.
Old Jan 1, 2009 | 09:51 PM
Fixed. Thanks a lot nub.
Old Jan 1, 2009 | 10:10 PM
The_Honda_Guy's Avatar
Just to chime in - yes, the o-ring will cause it to run rough. It will cause a vacuum leak in the engine. Glad to see you fixed it though.
Non Phixion
May 29, 2011 02:57 PM
tommyistommy
Jan 24, 2009 04:57 AM
AnAccordIsForever
Nov 13, 2007 08:31 AM
DrivinVtec
Oct 9, 2005 10:21 AM
EFGeeSeR
Oct 31, 2003 11:49 AM
