hondata, 9psi jrsc..... nitrous?
Old Aug 4, 2002 | 10:21 AM
hypa's Avatar
Default hondata, 9psi jrsc..... nitrous?
I've been thinking that since the drag season is almost over, I could end it in the 12's on a stock block with the use of a 50 shot nitrous system. Since I have the water injection, detonation wouldn't be as big a problem. Hondata also supports a second map for use with nitrous so it could be tuned for nitrous use without rendering it useless on the street when the gas is off. I have the sideband mounted in the car, and some spare time to tune it all.
Has anyone had any experience with this?
Is there anything I should watch out for or a specific setup?
Old Aug 5, 2002 | 07:54 AM
hypa's Avatar
Default Re: hondata, 9psi jrsc..... nitrous? (hypa)
to ht.
Old Aug 5, 2002 | 08:28 AM
Muad'Dib's Avatar
Corr Performance Pilot
My friend here hit 12's on his 6 psi jrsc teg with some Nawz on it. He did that on slicks of course. As far as the hondata goes I wouldnt know if they have the map that you're looking for. Perhaps try contacting them to see what they tell you.
Old Aug 5, 2002 | 11:36 AM
hypa's Avatar
Default Re: hondata, 9psi jrsc..... nitrous? (MouhadIb)
thanks for the reply.
I guess I'll post up the times and dyno #'s when it's all together.
Hopefully it will be my ticket into the 12's.
Old Aug 7, 2002 | 08:43 AM
Muad'Dib's Avatar
Let me know the setup that you go with and if you use Wet or dry and how. I'm also going to be venturing in this path for cooling of the charger. Good luck and keep us updated.
gosu08
Jun 22, 2008 11:49 AM
TeH PLAYA
Sep 28, 2004 04:35 PM
fredtoast
Feb 12, 2004 08:05 AM
gitwidit
Jul 1, 2003 08:48 PM
illi Adik
Dec 9, 2002 09:33 PM
