hondata, 9psi jrsc..... nitrous?
I've been thinking that since the drag season is almost over, I could end it in the 12's on a stock block with the use of a 50 shot nitrous system. Since I have the water injection, detonation wouldn't be as big a problem. Hondata also supports a second map for use with nitrous so it could be tuned for nitrous use without rendering it useless on the street when the gas is off. I have the sideband mounted in the car, and some spare time to tune it all.
Has anyone had any experience with this?
Is there anything I should watch out for or a specific setup?
Corr Performance Pilot
Re: hondata, 9psi jrsc..... nitrous? (hypa)
My friend here hit 12's on his 6 psi jrsc teg with some Nawz on it. He did that on slicks of course. As far as the hondata goes I wouldnt know if they have the map that you're looking for. Perhaps try contacting them to see what they tell you.
Re: hondata, 9psi jrsc..... nitrous? (MouhadIb)
thanks for the reply.
I guess I'll post up the times and dyno #'s when it's all together.
Hopefully it will be my ticket into the 12's.
