Big turbine and small compressor?
Old Dec 9, 2008 | 05:56 PM
aznkr4zyboi's Avatar
Default Big turbine and small compressor?
I'm looking into buying a turbo and its specs are .60/1.00 Would that be a bad combination? I remember hearing something like this somewhere but I tried searching but couldnt find anything.
Old Dec 9, 2008 | 06:08 PM
Tony the Tiger's Avatar
0.60/1.00 are just numbers assosciated with the compressor and turbine housing. You have failed to mention the wheel sizes and trim, and the actual turbo itself...lol The question is completely meaningless.
Old Dec 9, 2008 | 06:15 PM
It is a to4b, the rest of the information i dont have. Sorry i thought the given information was sufficient.
Old Dec 9, 2008 | 06:35 PM
stockb18c's Avatar
nope wasnt enough but seems like the number your given is there just lil to much on the exhuast side
Old Dec 10, 2008 | 06:16 AM
Schister66's Avatar
Man U FTW
Measure the wheels and report back. That's the only way we can truly know what you're working with. Also, what are your power goals?
Old Dec 10, 2008 | 06:43 PM
I'm looking to make around 200. Is it generally bad to have a large turbine and small compressor? If it has big negative effects i wont even consider getting it.
Old Dec 10, 2008 | 09:10 PM
Schister66's Avatar
Man U FTW
Until you measure the wheels, nobody can give you a straight answer. The end...
Old Dec 10, 2008 | 09:45 PM
biggoofy's Avatar
200 whp just get a t3t4
Old Dec 11, 2008 | 01:01 PM
DLB1994's Avatar
if you just want 200whp get a t3 , spool fast, cheap and allmost any spec will make 200whp
jarvis199
Nov 26, 2006 12:39 AM
ludelvr
Jul 30, 2003 09:08 AM
Pat
Jan 13, 2003 06:44 PM
austrian type-R
Sep 28, 2002 10:38 AM
CovertFI
Jun 26, 2002 10:15 AM
