Drilling turbine housing for larger (1/2") Studs ??
Old Dec 8, 2008 | 11:42 PM
InTraining124's Avatar
Default Drilling turbine housing for larger (1/2") Studs ??
I have a turbo manifold that has 1/2" studs installed in it. the issue is the bolt holes on my Garrett t3/t4 are about 3/8"s
is it okay to drill the turbine housing out to accept the 1/2" studs ?? anyone done this ?
Old Dec 9, 2008 | 05:53 AM
anyone ?
Old Dec 9, 2008 | 06:26 AM
shortyz21's Avatar
why not?
Old Dec 9, 2008 | 11:06 AM
im just concerned, wanna ask before i do anything.
anyone else ?
Old Dec 9, 2008 | 11:18 AM
Tippyman's Avatar
If you're not disassembling the turbo prior, I would try to stop shavings from going anywhere...
Old Dec 9, 2008 | 11:24 AM
Schister66's Avatar
Man U FTW
Its a cast iron housing, you can pretty much do what you want. Take the turbine side off the rest of the turbo to avoid foreign debris getting into it. Other than that, you should be in business...
Old Dec 9, 2008 | 06:06 PM
Tony the Tiger's Avatar
Just make sure the holes aren't enlarged too much that the nut doesn't have enough area to get a positive grip on... Last thing you want is to convert to allen bolts and remove all those 1/2" studs...
Old Dec 9, 2008 | 06:43 PM
"Last thing you want is to convert to allen bolts and remove all those 1/2" studs... "
Im not sure what you mean ? are you saying I should convert to Allen head bolts ? or that I might in the future ? why would I want to do something like that ?
Old Dec 9, 2008 | 07:39 PM
96 GSR-T's Avatar
I think he is saying dont make the holes too large....
make sure there is enough room on the nut side of the housing for you to tighten it all the way down, a 1/2" bolt has a pretty large nut......
pro547
Jun 20, 2005 12:54 PM
Acura_I-RS
Jul 11, 2003 05:51 PM
yellow blur
Apr 9, 2003 11:58 PM
zojirushi
Dec 2, 2002 08:54 AM
HondaCutter
Sep 6, 2002 12:28 PM
