Clocking a turbo
Old Apr 9, 2003 | 11:05 PM
yellow blur's Avatar
Default Clocking a turbo
Does anyone know which bolts to loosen to clock the turbo a different direction?
I'm assuming it's the 2 bolts that you can see in the middle, going through the exhaust housing and into the compressor housing? There are 4 of these bolts total. Thanks.
Ed
Old Apr 9, 2003 | 11:10 PM
GSRrR's Avatar
Default Re: Clocking a turbo (yellow blur)
mine was already clocked when i bought mine used. but i do not think its those. i believe its the other bolts that hold down the golden plates. (4 bolts on the bottom) and there are similiar ones on the turbine side.
BoM's Avatar
BoM
the 5 or 6 that hold the gold metal pieces.
same for the turbine
i had to do both so i could get mines just right.
Old Apr 9, 2003 | 11:16 PM
DD_JonnyLee's Avatar
Default Re: Clocking a turbo (GSRrR)
thats what i loosened on mine, hope that helps
-jonathan
Old Apr 9, 2003 | 11:18 PM
Default Re: Clocking a turbo (TrboGSR)
Are there certain torque specs I should follow, or just make them snug?
Old Apr 9, 2003 | 11:19 PM
I don't see how these golden plates would allow me to turn the housings... doesn't look like it's holding anything in place except for bracing it.
Old Apr 9, 2003 | 11:24 PM
LiLOtaku's Avatar
those bolts that are circled in red are the proper ones to clock/turn the housings. Try it out and see. When we did my friends turbo those are the xact ones we used. We just snugged them down and used the criss cross pattern when we tightened them up.
Old Apr 9, 2003 | 11:25 PM
Default Re: Clocking a turbo (LiLOtaku)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LiLOtaku &raquo;</TD></TR><TR><TD CLASS="quote">
Those are the bolts that turn/clock the housings. Just try it </TD></TR></TABLE>
I'll take your guys's word for it So are there any torque specs I should use or just make them tight?
Old Apr 9, 2003 | 11:48 PM
BoM's Avatar
BoM
loosen don't remove, and nice and tite. i just did it really tite
locked on a vice.
Old Apr 9, 2003 | 11:51 PM
lazerus's Avatar
Default Re: Clocking a turbo (BoM)
don't overtighten the bolts into the compresor housing it's aluminum!!! Call the place you purchased the turbocharger from for proper torque specs.. it shouldn't be all that much for the compresor side, probably a bit more for the exhaust/turbine side.
Old Apr 9, 2003 | 11:58 PM
shortyz's Avatar
Default Re: Clocking a turbo (lazerus)
yeah watch out on the alum side. just feel it.
Excelerate
Aug 17, 2006 10:51 AM
pro547
Jun 20, 2005 12:54 PM
cinq
Jan 14, 2004 07:41 PM
89 CRX SI
Apr 10, 2003 08:22 PM
HondaCutter
Sep 6, 2002 12:28 PM
