add mbc with out tunning...
Old Dec 7, 2008 | 01:52 PM
ONE*SICK*FERIO's Avatar
Default add mbc with out tunning...
hey guys
my car was tunned on wastegate .6 bar spring made 395@254tq
i was told by my tunner that it pushed 10.9psi at dyno
after the second time at the track i was able to record ONE of my runs
and the GM map sensor max reading was 9.1psi ...
now i just got a MBC that i want to install it and set it up to 10psi
but its possible without tunning
what should i look for?
i got a s300 hooked up to plx...
Old Dec 7, 2008 | 08:36 PM
bigb16's Avatar
Well if you're monitoring your A/F ratio then you should be okay turning it up to 10psi. If not then leave it how it is. What was the weather like when you tuned it comparing to the track conditions? You could have dropped some boost due to higher heat.
Old Dec 7, 2008 | 08:45 PM
mtber's Avatar
Give your tuner a call to ensure he properly scaled the tune for the higher boost levels you are wanting to run. Running a wideband oxygen sensor is a must too..
2ndchirp
Jul 14, 2009 05:55 AM
1badteg
Jun 24, 2009 02:00 PM
LSej1
Jul 19, 2008 03:51 AM
dartdc97
Feb 15, 2007 08:42 PM
redline201
Dec 3, 2002 04:35 PM
