tuning ?s
Old Dec 3, 2002 | 04:20 PM
redline201's Avatar
Default tuning ?s
ok im boosting my b16a very soon and my question is
i plan on running the stock .45 bar of boost with the tial wastgate (on the street)
then im thinking of buying a manual boost controller to boost say 8 psi at the track
do i have my hondata tuned to run at .45 bar or 8psi
sorry im a noob
Old Dec 3, 2002 | 04:35 PM
boostaholic's Avatar
Default Re: tuning ?s (redline201)
Since you're running a hondata unit, i assume that you will be using a 3bar map sensor. With the case of that, you have the entire rpm and map values up to 3 bar to fill so technically you could boost to that. But usually tuning on the dyno, you will tune up to the your highest set boost level and set the values above that to a safe level in case you over boost.
civic_66
Feb 14, 2007 07:22 AM
boosted96teg
Feb 4, 2007 06:53 PM
JusT a Cx
Feb 24, 2004 05:58 PM
Ek00fbp
Oct 8, 2003 10:08 PM
SUMORex
Sep 20, 2002 12:00 AM
