$5000..... Need a turbo setup...
Old Aug 1, 2002 | 08:50 AM
All Motor R's Avatar
Default $5000..... Need a turbo setup...
I'm a Honda-Tech newbie in need of some help!
I have been saving for quite a while, and I am finally ready to turbo my teg. I have a GSR Motor with Type R internals. I have $5000 for a turbo setup, and that is all. What can I get?
Old Aug 1, 2002 | 08:52 AM
FOrSfEd's Avatar
Default Re: $5000..... Need a turbo setup... (Amsco99)
You can build a pretty nast *** set up for that, I would go drag and hondata of course and you would still have money left over for other things.
Lee
Old Aug 1, 2002 | 08:58 AM
turbo craig's Avatar
Default Re: $5000..... Need a turbo setup... (Rex2nv)
well...it really depends on what u do: if u wanna keep ac, if u want high boost, if u want to sacrifice streetability for speed. do a search ull find ure answers if u want to get a preasemled kit get the revhard 2c with a hondata and some bigger injectors and find a good tuner u might wanna think about changing ure internals cuz its harder to tune a higher compression motor with turbo but it can b done
Old Aug 1, 2002 | 09:01 AM
Smashback's Avatar
Use some of that money to buy your GSR cams back
Old Aug 1, 2002 | 09:09 AM
Default Re: $5000..... Need a turbo setup... (mplex2000)
I want to keep my A/C and hit mid 13s all day... i dont wanna build my bottom end right now. im happy with a headgasket.
Old Aug 1, 2002 | 09:13 AM
FOrSfEd's Avatar
You should at least replace your piston rings, and if you have the right fuel mixture you can run stock internals with no prob.
Lee
Old Aug 1, 2002 | 09:37 AM
MyWhiteCivic's Avatar
$1200...: T3/T4 turbo (ball bearing)
$50-75..: Custom 2.5 inch piping
$240.....: Tial wastegate
$200.....: not sure what's the best bov (maybe a greddy?)
$80.......: turboxs mbc
$1250....: Hondata 4b or AEM
$400.....: Revhard manifold
$250.....: down pipe (not sure how much these cost
$250.....: 440 injectors
$12.......: sparkplugs
$100.....: fittings/braided lines/etc.
$300.....: Custom intercooler (I have a 28" 7x2 row intercooler with 2.5 inch inlet/outlet for sale)
$400.....: Tuning (4 hours)
TOTAL: $4757 (and you still have enough money for a lot of along the way!)
Did I miss anything?
That would definatly be a quick a$$ car if you put $5,000 into it!
Old Aug 1, 2002 | 10:34 AM
Default Re: $5000..... Need a turbo setup... (MyWhiteCivic)
I was actually thinking about getting in on that Importparts.com deal for the Drag 3 Kit since it is $2699.99 + shipping. I do not know enough about turbo where I can piece together a kit. I want a turbo kit where I can keep my Air Conditioning, and hit mid 13s, and just have fun. Do you think normal pieced together kit like Drag is more practical?
Old Aug 1, 2002 | 11:01 AM
JMinSi2000's Avatar
Get the drag3 kit from import parts and upgrade to tial wastegate. Sell the FMU and fuel pump and get a walbro intank pump, hondata, and 440-550 injectors. Get a ss oil return line too.
Old Aug 1, 2002 | 11:19 AM
Default Re: $5000..... Need a turbo setup... (JMinSi2000)
How does this sound:
$2699.99 ---- Drag 3 Kit
$150 --------- Tial Wastegate
$79 ----------- Greddy Turbo Timer
$566.10 ------ Apex'i AVC-R
$275 ---------- RC 440cc Injectors
$1250 -------- Hondata Stage 4b
$300 --------- Inline Pro Headgasket
Is there anything else I need besides tuning? I will be boosting 10lbs max
Old Aug 1, 2002 | 11:27 AM
KooK's Avatar
Mustang Sally
Thats alot of money for just 10 pounds...
Personally, I would buildup my engine before I got any type of forced Induction...
Old Aug 1, 2002 | 11:40 AM
bruthaboost's Avatar
Unless your'e going to be tuning yourself, you don't need the 4b. Spend the extra 500 towards something else like a lsd. Turning becomes a different experience.
Old Aug 1, 2002 | 11:52 AM
Why would you want a walbro in tank if your running stock fuel pressure?
Old Aug 1, 2002 | 11:57 AM
brcivic411's Avatar
Add the hondata intake manifold gasget $60
Old Aug 3, 2002 | 06:28 PM
Turbo Laser's Avatar
Default Re: $5000..... Need a turbo setup... (brcivic411)
Does anyone else think that ball bearing turbos are a waste of $$$ for our applications?
Old Aug 3, 2002 | 09:12 PM
AB16A2T's Avatar
Default Re: $5000..... Need a turbo setup... (NOCARLOSER)
Depends on how you look at it really. If you want quicker spool up times, (important considering we have small engines that take a while to build boost) than they are waste of money.
Old Aug 3, 2002 | 09:15 PM
piscorpio's Avatar
Default Re: $5000..... Need a turbo setup... (Ares81883)
wait, wouldnt that mean they aren't a waste of money? I thought ball bearing turbos spooled quicker? Did I just misunderstand you?
Old Aug 3, 2002 | 09:35 PM
BlueSi2k's Avatar
you will need a new clutch and you might also want a 3" exhaust
Old Aug 3, 2002 | 09:53 PM
InfamousDX's Avatar
Default Re: $5000..... Need a turbo setup... (BlueSi2k)
go hit up Ben's deal from importparts.com and hook up ALL the extras. it will do your body good.
P'cola GSR
Jul 27, 2010 11:39 AM
Liquidgsr
Sep 9, 2007 06:35 PM
streetlights
Jun 10, 2007 11:34 PM
Gsr94black
Nov 15, 2004 09:19 PM
94sisol
Jan 21, 2004 06:00 AM
