my IC piping keeps blowin apart
Old Nov 24, 2008 | 06:41 AM
killacam661's Avatar
Default my IC piping keeps blowin apart
i have a built gsr on 5 psi and while driving and starting to boost my intercooler piping keeps blowing apart...( im using stupid ebay piping for now :/ ) wat would be causeing this?
Old Nov 24, 2008 | 06:42 AM
WhiteEJCoupe's Avatar
get vband....lol...i dono just get good silicon adaptors and good clamps and clamp the **** outta it
Old Nov 24, 2008 | 06:56 AM
slow96coupe's Avatar
found your problem
Old Nov 24, 2008 | 07:05 AM
Schister66's Avatar
Man U FTW
If you're using pipes without a bead at the end and crappy worm clamps, that might be your problem. You can use hairspray on the pipe (after cleaning it thoroughly) and then tighten your clamps. It wont solve the problem forever, but it will definitely help. Otherwise, get bead rolled pipes and Tbolt clamps next time...
Old Nov 24, 2008 | 07:20 AM
ok thanks guys.
will i be able to get the pipes i already have beaded?
Old Nov 24, 2008 | 07:34 AM
96 GSR-T's Avatar
yes take them to a fab shop that has a bead roller, or have a welder weld a lip around the pipe. I always read these threads and I run 20+ psi with no bead or welded lip and I have NEVER blown a charge pipe off, just using t-bolt clamps
Old Nov 24, 2008 | 07:40 AM
boostedcivicsir's Avatar
Mr. Badwrench
yeah put a bead on the end of the pipes, and get yourself a can of 2+2. when putting the couplers on, wet them with the 2+2. the slide real well til it evaporates, then they are nice and tight.
Old Nov 24, 2008 | 09:21 AM
eg crunkmonster's Avatar
i never had beads at the end of my pipes and never had that problem....i just cleaned off the ends of any oil or anything with some alcohol and used some nice vibrant silicon couplings with some worm clamps and never had a problem and thats with 20+ psi and more with c16
Old Nov 24, 2008 | 10:21 PM
liam821's Avatar
25 Year Member
try hairspray....seriously, spray hairspray over the pipes then slip on the coupler and tighten with a t-clamp. Works like a charm.
Old Nov 24, 2008 | 10:46 PM
RedneckRicer's Avatar
i use some acetone on my pipes and couplers they bite and grab. I have my car seeing 17lbs. My Room mates car see's 20+ psi daily and he is using cheapy ebay piping clamps and couplers
89efDUSTY
Jan 12, 2007 04:32 AM
JDM-Civic-Hatch
Mar 28, 2005 08:09 PM
Boost Addict
Sep 24, 2004 10:12 PM
-Trinitron-
Oct 3, 2003 12:25 PM
revhrdls
Sep 27, 2001 06:36 AM
