Car wanting to overheat if sitting still... revvv and it's better?
Hey everyone.
Swapped in a d16z6 into my 93CX about 2000 miles ago. Everything was great, loving the hp upgrade until yesterday.
Was sitting waiting in heavy traffic, and all of a sudden noticed my temperature gauge slowly rising. Traffic moved, and as I reved, it went down. After that, any time I slowed down, or came to a stop, here it came.
I also noticed a bit of over pressurization around the radiator cap. It's new. And there was a puddle of coolant ontop of the fan shroud. If I stuck my ear down to it, I could hear a slight hissing... uh oh...
I changed the headgasket on my old d15 and then it started burning oil BAD. Please don't tell me i've got another blown head gasket?!
There's no smoking at all...
Would a bad thermostat effected by revs? I sort of wondered if maybe it was the water pump, but it's supposed to be new.
Fan is kicking in after it's already "more the 1/2 way up the temp gauge", but then cuts off right away. Comes on for a few seconds, and cuts off... shouldn't it stay on?
Both coolant hoses are hot... shorter one is HOTTER... by a bit...
Any ideas?
Any ideas?
check and see if your radiator is leaking , even if the water pump is new check for coolant leak at the bottom of timing cover
i had the same problem with my 97 ex. It was a bad thermostat and the wrong ECU. The fan kicked on @ halfway and then just turned off. You can easily wire the fan to be on all the time like many people that I know did. This way as soon as you turn the key it comes on. If your sitting still and you rev in Neutral and the temp goes down then it could be the water pump's blades have broken off so it doesnt really move coolant until higher RPMs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonvtec92 »</TD></TR><TR><TD CLASS="quote">Thanks for the replies everyone. So if it were a blown head gasket; reving up the motor wouldn't have any effect on the temp level?</TD></TR></TABLE>
I dont see any reason why it would.
if your hg is blown look at your overflow tank. if its black then it is blown. i had that issue in my Y8. my buddy has a teg that tries to overheat when not reving as well. replaced the radiator because it was leaking and the thermostat and wp but still no good. i need help on this to
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bob Dole! »</TD></TR><TR><TD CLASS="quote">Does you're radiator fan turn on?</TD></TR></TABLE>
holy **** did you even read the OP?
Thanks all...
Radiator is less then 6 months old.
I've been working all day and haven't had a chance to look at it anymore. Luckily I have a spare vehicle.
I'll try and bleed the system and see if that helps.
If not, i'll replace the thermostat... etc...
Thanks everyone
Thanks everyone
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">holy **** did you even read the OP?</TD></TR></TABLE>
I guess not...
Yes the radiator fan comes on. It doesn't come on until AFTER it probably should, and then just turns off after MAYBE 30 seconds. It'll do the same thing again and again with perhaps a minute of down time inbetween.
I guess not...
Check your engine grounds.(Valve cover, Transmission, and the thermostat grounds.)
My tranny ground was loose, and my 97 Integra started to over heat, I was lost untill I looked over ground wires, and it was the tranny ground wire.
check the coolant level...and check the reservoir tank...my teggy was starting to overheat cus the reservoir cap wasnt screwed down it was just sitting there...i was freaking out cus i dont have a thermostat ha ha worried it was just circulating hot coolant but it went away after i screwed down the cap
uselesshuman
17
Sep 5, 2010 06:43 AM
mx621
Jan 16, 2006 03:22 PM
