Need Help: Swap wont start
Old Oct 23, 2008 | 09:28 AM
egreenmachine's Avatar
Default Need Help: Swap wont start
So heres the deal been working on this car for awhile, picked up parts from all over the place. Body is a 93 Dx hatch, motor is a ls/vtec with a 00 gsr head on a b18a bottom end. Picked up the motor and guy said it was being run on a chipped p28 when he built it. Swapped the motor into my hatch however doesnt want to run. Checked all connections and 3 grounds (v.c., trans, battery) everything checks out. The motor turns but wont start. Checked all spark plus and all are fine and not getting any cels. The ecu is a p06 which was converted to a P28 and chipped for this setup professionally. Anyone have any suggestions or have any problems like this before?
Old Oct 23, 2008 | 09:33 AM
lsvtecturbosol's Avatar
Default Re: Need Help: Swap wont start (egreenmachine)
You said you checked all the grounds (V.C., Trans, Battery) there is one more. it is on the Thermostat housing. Check and make sure that is tight. Other than that not sure how to help without being there in person.
Old Oct 23, 2008 | 09:46 AM
Black4thgenEF's Avatar
Default Re: Need Help: Swap wont start (lsvtecturbosol)
Are you getting spark and fuel?
Old Oct 23, 2008 | 10:58 AM
sorrule's Avatar
check timing and what the said above^
danny_ha
21
Nov 14, 2007 08:21 AM
egreenmachine
Nov 2, 2007 09:52 AM
ProjectEG8
Jul 20, 2007 11:12 PM
wannab20hatch
13
Dec 3, 2003 04:22 AM
EndlessGarageEG6
Apr 26, 2003 12:34 PM
