Just swapped in a dx motor into my standard now it wont start.
Old Nov 24, 2003 | 01:10 PM
wannab20hatch's Avatar
Default Just swapped in a dx motor into my standard now it wont start.
The head on my standard motor was warped so i swapped in a dx motor from a friends hatch and now it wont start everythign is hooked up right. It has a new distributor,cap,rotor,plugs and plug wires. The car cranks but doesnt start. What is the problem?
Old Nov 24, 2003 | 01:34 PM
onePOINTsix's Avatar
Default Re: Just swapped in a dx motor into my standard now it wont start. (wannab20hatch)
check fuel, spark and all the fuses
Old Nov 24, 2003 | 04:22 PM
ImportsCRX's Avatar
is the timing right?
Old Nov 25, 2003 | 08:11 AM
Default Re: (ImportsCRX)
Spark is there and timing is right. No fuses are blown
Old Dec 2, 2003 | 10:14 AM
Default Re: (wannab20hatch)
I replaced the wiring harness,injectors,ecu's andit still wont start. Its gettin fueland spark and the timing is right. Just keeps on cranking but no start
Old Dec 2, 2003 | 10:18 AM
virginia_dude's Avatar
If it had fuel spark and the timing right it would run, go back and check it over again something is wrong. Sorry to be blunt, but if the motor ran before and it was hooked up right it would work.
Old Dec 2, 2003 | 10:21 AM
I'll bet you have your distributer in 180 degrees out of spec.
Old Dec 2, 2003 | 10:22 AM
Default Re: (virginia_dude)
Ive been workin on it for a week and it still wont run everything is right. This is like the 5th time ive done this swap and this is the first one ive had trouble with.
Old Dec 2, 2003 | 10:23 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by virginia_dude &raquo;</TD></TR><TR><TD CLASS="quote">If it had fuel spark and the timing right it would run, </TD></TR></TABLE>
what if it does not have any compression?
Old Dec 2, 2003 | 10:30 AM
Default Re: Just swapped in a dx motor into my standard now it wont start. (virginia_dude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by virginia_dude &raquo;</TD></TR><TR><TD CLASS="quote">I'll bet you have your distributer in 180 degrees out of spec.</TD></TR></TABLE>
Cant be 180 out. Only goes in one way and one way only haynes manual even says that. Honda designed it so that it can only go in one way
Old Dec 2, 2003 | 12:11 PM
88DXCRX's Avatar
firing order correct?:
Old Dec 2, 2003 | 12:19 PM
Caleb V's Avatar
Default Re: Just swapped in a dx motor into my standard now it wont start. (88DXCRX)
Have you checked the distributor rotor and made sure the screw didn't fall out. You will still get spark but it will be intermittent when you pull a plug to check that you have spark it will appear to be just fine while the rotor is freewheeling. I got baffled by this once and usually look there first for not wanting to start conditions. Check over your grounds as well.
Old Dec 3, 2003 | 04:21 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wannab20hatch &raquo;</TD></TR><TR><TD CLASS="quote">
Cant be 180 out. Only goes in one way and one way only haynes manual even says that. Honda designed it so that it can only go in one way</TD></TR></TABLE>
ZC distributor shaft I mean housing obviosly fits one way, ZC distributer can be put in 180 out. And many vehicles can be put in 180 out, you would be surprised how many nostarts can be attributed to that. I don't have my old DX distributer laying around to check what you said. But I still have my old engine.
Old Dec 3, 2003 | 04:22 AM
Default Re: (88DXCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88DXCRX &raquo;</TD></TR><TR><TD CLASS="quote">
what if it does not have any compression? </TD></TR></TABLE>
If it has no compression it obviously could not have been running befoire he put it in his car. And he said it was. That is my point.
Spody02
12
Sep 9, 2008 10:16 AM
dumpeDc2
Dec 30, 2004 09:25 PM
C-REX 88
20
Apr 29, 2004 08:41 PM
bambam
Nov 19, 2003 12:44 PM
