Hatch trouble
Old 11-02-2007, 07:44 AM
egreenmachine's Avatar
Default Hatch trouble
Hoping I can get some help with some problems I'm having with my hatch.
Setup:
93 dx civic shell
Ls/V
-B18a bottom end/GSR head
-skunk 2 IM
Problem Im having is car would start and run, however took the battery out one day to charge it and when I put it back in now car wont start. Battery is charged even tried jumping it. No luck. Motor turns over but I dont think there is a spark. I think the dizzy is working considering the car was working before, however is there a way to check? Could it possibly be a ground?
Old 11-02-2007, 07:49 AM
crazyguy's Avatar
Default Re: Hatch trouble (egreenmachine)
when u removed the battery, u only disconnected positive and negative wires,right? does fuel pump prime? check for your starter and main relay..
Old 11-02-2007, 08:33 AM
Default Re: Hatch trouble (crazyguy)
Yea only disconnected postive and negative, I think fuel is fine cause I smell gas if I try to start it.
Old 11-02-2007, 08:47 AM
sleeperrex's Avatar
pull a plug wire and put a plug in it....and put it near a grounding point in your engine and have your friend crank your car....you should see spark, if not time for a new dizzy
Old 11-02-2007, 09:18 AM
~lil_mossy~'s Avatar
check your grounds... ???
Old 11-02-2007, 09:25 AM
MonkeyMagic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egreenmachine &raquo;</TD></TR><TR><TD CLASS="quote">Hoping I can get some help with some problems I'm having with my hatch.
Setup:
93 dx civic shell
Ls/V
-skunk 2 IM
Problem Im having is car would start and run, however took the battery out one day to charge it and when I put it back in now car wont start. Battery is charged even tried jumping it. No luck. Motor turns over but I dont think there is a spark. I think the dizzy is working considering the car was working before, however is there a way to check? Could it possibly be a ground?</TD></TR></TABLE>
checked fuses? all kinds of things can potentially go wrong with battery replacement
-check fuses
-check for spark
-check for fuel
-test ecu in other car to rule out
-test dizzy in other car to rule out
hopefully by then you've got it cause those are most common things
if not come back and search here and google
Old 11-02-2007, 09:33 AM
Default Re: Hatch trouble (MonkeyMagic)
Hey everyone thanks for your help. Went through tightened my grounds, then checked the dizzy, dizzy was fine so i pulled and cleaned all my sparks and disconnected and re connected all my plug wires turned it over and it started up. Thanks for all the help.
Old 11-02-2007, 09:52 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egreenmachine &raquo;</TD></TR><TR><TD CLASS="quote">Hey everyone thanks for your help. Went through tightened my grounds, then checked the dizzy, dizzy was fine so i pulled and cleaned all my sparks and disconnected and re connected all my plug wires turned it over and it started up. Thanks for all the help.</TD></TR></TABLE>
do a burn-out and get us some pizza and beer!
Steveramirez21
05-11-2013 09:40 AM
ekVtecPower
14
03-27-2006 08:47 PM
zacatkings
27
03-22-2006 05:26 AM
quiambao1180
07-13-2004 10:50 AM
Hybrid CRX
01-09-2004 08:17 PM
Quick Reply: Hatch trouble
