driver side window falls off track wtf
its a honda thing, take armoral or wd40 and spray it on the rail it will help a lot. you can also adjust the lower bolt near the speaker housing. armoral works the best though.
its also pretty normal if the window comes off track only when rolled all the way down. the bushings in the regulator wear out. the window regulators are super cheap i would jsut replace it.
OMG ... this happens SO MUCH that i didnt even put my speaker back in the door. but i noticed tat i went ALL of summer without it falling of its track.. and then one foggy and wet night it falls off... AAHH. but at least its an easy fix...
happened to mine it was just one of the bolts in the door came loose .Its one of the bolts that holds th rail in place .Might want to check that out quick fix. Also there are 2 holes in the door where a ratchet goes in no need to take out the speaker . just line the holes up where you can get the tool in fixed in 5min. Good luck with the problem.
This is a writeup on this issue:
https://honda-tech.com/zerothread/2061336
The FAQ thread is stickied at the top of the forum...it has all of these common little problems solved.
do you still have photo can re-load?
00ekcoupe
13
Aug 27, 2005 10:52 AM
