front door window
front door window
Mine is a Honda Civic EX 1997 two-door.
The rubber lining around my driver window has a problem - window stops halfway while sliding up.
Has anyone had this problem? Can I just buy the rubber lining at dealer?
Re: front door window (96coupe)
Thanks for writing.
Sure enough, the window is off track. I can see it when it slides high enough.
There seems to be some damage to the lining too, so I though that caused the problem.
But in fact this might have been caused by the window sliding up off track.
Do you know what to do to get the window back in track?
G
G
Re: front door window (Berwyn74)
mine had done the same thing. it falls of the track and wont go up because it gets cought underneath the mirror. i have manual ones. i put it back on track and it just falls back off again after i use it
theres a screw on the bottom after u take the door panel off. you loosen it...put the window on track then tighten the screw down and ur set.
inaety
11-03-2009 08:20 PM
