Valve seals/springs MADE EASY!!
Old Oct 7, 2008 | 09:57 AM
boostd92's Avatar
Default Valve seals/springs MADE EASY!!
My EK with b18C1 needed new valve seals. The car has great compression and nothing else wrong with the motor. Everywhere I went to quoted me labor hours for taking the head off, resurfacing, suggested a new headgasket, all to just replace valve seals.
I found a DIY online that suggested using a vice, some zip-ties, and a torch to do it with the head still on the car, but the method look awfully dangerous and I was looking for a cleaner solution.
Well I found an awesome tool to do the job without pulling the head, and it's really simple and fairly cheap. I put the company's card in the pic so anyone who needs to find one new, can.
Modified by boostd92 at 1:33 PM 10/8/2008
Old Oct 7, 2008 | 10:29 AM
CARMA_626's Avatar
I drive a G35, it's silver, surprised?
Default Re: Valve seals/springs MADE EASY!! (boostd92)
Wow, that has to be one of the best tools I've seen for Honda's.
When I did my valve spring/retainer/guide intall, it was very difficult since I was using one of those Autozone rental kits...which was probably designed for a domestic.
Very cool.
Old Oct 7, 2008 | 10:55 AM
stocker2shocker91's Avatar
I requested a short story for a title.
Default Re: Valve seals/springs MADE EASY!! (CARMA_626)
sweet action im going to spread this around to a few other sites..
Old Oct 7, 2008 | 11:02 AM
boostd92's Avatar
Somebody buy mine! pacakged and ready to ship.. hehe
Old Oct 7, 2008 | 11:13 AM
racebum's Avatar
you are a trooper using a v8 spring compressor on the teg. when i was tearing my motor down i tried using my v8 compressor, gave up and just beat the retainers with a hammer 'till the springs went flying across the garage.
Old Oct 7, 2008 | 11:44 AM
steveharrmr23's Avatar
very nice
Old Oct 7, 2008 | 03:32 PM
jvtec95's Avatar
Default Re: Valve seals/springs MADE EASY!! (steveharrmr23)
I used this when rebuilding my head, works fantastic.
WELL worth the $$ spent, even to use it once.
Old Oct 8, 2008 | 12:31 AM
XxNampsterxX's Avatar
Default Re: Valve seals/springs MADE EASY!! (jvtec95)
I have this tool also. Works great
Old Oct 8, 2008 | 09:14 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (boostd92)
wow that was a quick sell.
Might want to edit your post to say it's been sold.
Old Oct 8, 2008 | 09:20 AM
Community Builder
Would be nice if the website spelled VTEC correctly haha
Why couldn't they have made it out of hardened steel. Would that be more expensive than aluminum? It would certainly be stronger, less likely to bend.
Old Oct 8, 2008 | 09:28 AM
jvtec95's Avatar
Default Re: (PatrickGSR94)
The plate thickness is sufficient that it will not bend/deform. I'm guessing they used aluminum because it is easier to machine than steel.
I think the only downside to aluminum is the possibility of cross-threading, but unless you're really not paying attention that shouldn't be an issue.
But there's no excuse for misspelling VTEC!
The nicest thing about this tool is that you can properly space out your keepers (directly across from each other), which is nearly impossible with the compression type tools.
80 dolla crx hf
Sep 8, 2014 01:28 PM
jyacoba2009
18
Sep 29, 2009 05:41 PM
boostd92
Oct 7, 2008 11:23 AM
biggie2005
Feb 26, 2004 06:23 PM
civicracer1993
Apr 6, 2003 01:01 PM
