b17a1?
Old Oct 1, 2008 | 04:48 PM
josh94civic's Avatar
Default b17a1?
ok yet agin i have another question. i've come across a b17a1 motor for sale with a jdm b16 s1 trany, and i can't find anything on the b17a1 motor and for some reason my computer wont let me go to google. will this motor fit in my 94 civic and how much of a pain is it to do the swap? is it a good swap to do?
Old Oct 1, 2008 | 04:56 PM
B16AGUY's Avatar
Default Re: b17a1? (josh94civic)
Here are the Specs for you... I have no clue if this will fit a 94 civ... from what I can see on the forums, it is possible but I am not sure what you'll need.
Acura B17A1 Engine JDM
Displacement (cc):
1678
Power (bhp@rpm):
160 @ 7,600 rpm
Torque (ft/lbs@rpm):
117 @ 7,000 rpm
Compression Ratio:
9.7:1
Bore (mm):
81
Stroke (mm):
81.4
Cam Design:
DOHC
Valvetrain:
VTEC
Old Oct 1, 2008 | 05:43 PM
if anyone can help me with weither it will fit in my civic or not i would appreciate it greatly. i mean it's a great deal it's the b17a1 gsr motor out of a 92 integra with bored .25mm over oversized ctr pistons, jdm itr head port and polished, all new b17 rods, new crankshaft, all new seals and headgasket, northodox racing pulley, ebay headers, throttle body spacer, jdm b16 s1 tranny with stage 2 clutch and lsd. all of the cvaxles and motor mounts computer and all for the swap.
Old Oct 1, 2008 | 05:48 PM
Kendall's Avatar
The B17A1 is basically a stroked B16A. The S1 is a cable tranny. Find a mount setup for putting a B16 with a cable tranny into your car and you'll be okay.
Old Oct 1, 2008 | 05:49 PM
MiMiK's Avatar
any b-series motor will fit except the b20 from the 3rd gen prelude. make sure you get a hydro transmission unless you want to switch to a cable clutch.
Default Re: (Kendall)
will it drop right in though? or is it a hard swap?
Old Oct 1, 2008 | 05:50 PM
Default Re: (MiMiK)
im sorry but whats a hydro trans?
MiMiK's Avatar
it's easy. i did a swap in my backyard with basic hand tools. but i'm pretty mechanically inclined
Old Oct 1, 2008 | 05:52 PM
MiMiK's Avatar
hydraulic transmission... out of a 92+ civic and 94+ integra w/ a b-series.
Old Oct 1, 2008 | 05:55 PM
ltrkstr2k's Avatar
Default Re: (MiMiK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MiMiK &raquo;</TD></TR><TR><TD CLASS="quote">hydraulic transmission... out of a 92+ civic and 94+ integra w/ a b-series.</TD></TR></TABLE>
damn beat me to it lol. its a easy swap. with a little searching and mechanical skills you can do it.
Old Oct 2, 2008 | 08:10 PM
so it should bolt right in for the most part? someone told me something about one of motor mounts not fiting in the right spot? but idk.
Old Sep 13, 2012 | 05:35 PM
joeyEGK's Avatar
Default Re: b17a1?
i have a b17 :D
Old Sep 13, 2012 | 06:27 PM
NotAJDMFanBoy's Avatar
Default Re: b17a1?
B17 was from the 3rd gen Integra GSR. As said, it's a stroked B16 with a special crank, rods, pistons for just that engine. The block and head are normal B16 parts.
Mechanically it's bolt in, electrical you may need to get a distributor to match your generation of car (obd1 for 92-95 for example). Injectors you may need to check on.
Old Sep 13, 2012 | 06:33 PM
DCRB's Avatar
Default Re: b17a1?
the first gen gsr is obd1. dizzy will be plug and play. wire up vtec and i believe a knock sensor and you're good to go.
a hydraulic clutch is similar to hydraulic brakes in it uses a hydraulic piston with a reservoir full of brake fluid to move the clutch arm vs a cable clutch which like a motor cycle uses a a mechanical cable that attatches to the transmission from the clutch pedal.
while the motor is special, the swap is not any different from any other b series swap
Old Sep 13, 2012 | 06:55 PM
Deetz's Avatar
Crazy Honda Guy
Default Re: b17a1?
It is from a 2nd gen integra, and was the 1st gsr made.....it came in OBDI only, and still used a cable tranny, they short geared YS1, which will not bolt into an EG civic without a hydro to cable conversion
Old Sep 13, 2012 | 07:05 PM
Hidenplanvew's Avatar
Default Re: b17a1?
it would be a waste to convert a car from hydro to cable... just get an LS or Gsr hydro trans
Old Sep 13, 2012 | 08:02 PM
Former User's Avatar
Default Re: b17a1?
Originally Posted by joeyEGK
i have a b17 :D
Don't bump old threads for no reason.
Thread closed.
dls_tech
18
Jul 30, 2011 05:00 PM
Corksil
29
Aug 30, 2009 07:07 AM
ej1civic
Aug 3, 2003 12:00 AM
94_civicEx
19
Jul 10, 2003 10:23 PM
Hard2Find
Dec 12, 2001 07:33 PM
