injector options
Old Aug 29, 2008 | 11:17 AM
fatpride111's Avatar
Default injector options
building up my motor, and i was wondering what injector options i have... basicaly have a ls/vtec, with buddyclub spec IV cams.
would 440's be good? im on a tight budget build, so im looking into some dsm injectors.. whats needed to put those on a gsr rail? would i have to upgrade my fuel pump also?
TIA
Old Aug 30, 2008 | 07:28 AM
... Bump
Old Aug 30, 2008 | 07:30 AM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: injector options (fatpride111)
310 are fine.
DSM
Old Aug 31, 2008 | 10:21 AM
dont get DSM's?
alright, thanks, ill look for a set of 310's
Old Aug 31, 2008 | 10:28 AM
N20civicB18's Avatar
You can use 440's but they are overkill. 310's are more then enough for most setups on here.
If you do use DSM injectors they will fit right in but you need to run a resistor box if you are obd1+, if you are obd2 you need to change the clips and, no matter what you need to dremel out the injector O rings (O rings that go into the intake manifold).
I would put a Walbro 255 in there since they are cheap.
Old Aug 31, 2008 | 07:30 PM
awesome, 310's it is.
DSM's seem like alotta work, and ... well.... they are DSM...
thanks for the info
Old Sep 2, 2008 | 10:12 AM
found a good deal on 440's. 310's seem to be more expensive for some reason... no one wants to get rid of them cheap enough
so it would run just fine with 440's? or would 310's be worth it for some reason...?
Old Sep 2, 2008 | 11:09 AM
mar778c's Avatar
Community Builder
Default Re: (fatpride111)
440s will work but you will need some tuning help to get it started and an acheiving good ring seal. If you aren't careful 440s will wash out your rings.
Old Sep 2, 2008 | 11:11 AM
Default Re: (mar778c)
correct, get it all put together and bring it right to your tuner on the flatbed
Old Sep 2, 2008 | 11:24 AM
damn, i was hoping i'd be able to start it up at home, and take it to them after we changed the oil. i was thinking of phearable.net and maybe he could make me a decent enough tune to get it started and drive it there, think he'd be able to handle the 440's on there just for a quick start up, and drive it 20 miles to the tuner?
Old Sep 3, 2008 | 04:21 AM
00b20vtecoupe's Avatar
im running rc 440's on my b20 vtec and its fine. we street tuned it with my tuner for like 30 miles on them then threw it on the dyno but get a walbro fuel pump 255lph its like 100 bux. If you have the money i would get a fuel ruel to depending on how big your build is.
Old Sep 3, 2008 | 05:36 AM
98vtec's Avatar
moderator emeritus
Default Re: (00b20vtecoupe)
RDX
cheap and efficient
Old Sep 3, 2008 | 06:50 AM
00Red_SiR's Avatar
All Motor Mentor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fatpride111 &raquo;</TD></TR><TR><TD CLASS="quote"> i was thinking of phearable.net and maybe he could make me a decent enough tune to get it started and drive it there, think he'd be able to handle the 440's on there just for a quick start up, and drive it 20 miles to the tuner?</TD></TR></TABLE>
that's the way I'd go.
Old Sep 3, 2008 | 09:38 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00b20vtecoupe &raquo;</TD></TR><TR><TD CLASS="quote">im running rc 440's on my b20 vtec and its fine. we street tuned it with my tuner for like 30 miles on them then threw it on the dyno but get a walbro fuel pump 255lph its like 100 bux. If you have the money i would get a fuel ruel to depending on how big your build is. </TD></TR></TABLE>
sweet, good to know. i want to buy a walbro, but im kinda short on cash.. ill probably buy one in about 2 weeks, unless i can find a cheap one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">RDX
cheap and efficient</TD></TR></TABLE>
bought RC 440's from one of the audio mods for $115 shipped
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00Red_SiR &raquo;</TD></TR><TR><TD CLASS="quote">
that's the way I'd go.</TD></TR></TABLE>
heard good things about them
martial
Feb 21, 2010 08:34 AM
95dc2teg
Jul 29, 2006 11:01 PM
b18c1wes
Dec 9, 2004 02:44 PM
Smooth-GSR
Mar 26, 2004 10:16 PM
LEON
May 10, 2002 02:57 PM
