DSM 450's question.....
Old Mar 25, 2004 | 09:53 AM
Smooth-GSR's Avatar
Default DSM 450's question.....
Do I need the 'clip's to get them installed? The seller says that they do not come with clips. Its for my 99 Integra.....
Thanks!
Old Mar 25, 2004 | 09:56 AM
Nextelbuddy's Avatar
Default Re: DSM 450's question..... (Smooth-GSR)
you either need the DSM clips or a set of OBD1 injectors clips. but with the obd1 clips yo still ahve to cut out the little notch in the injectors to get them to fit perfectly.. eith er way there is no way your obd2 injector clips will fit the DSM injectors.
BTW you will also need to wire in a resistor box. since DSM injectors are peak and hold and your car is a saturated injector setup..
Old Mar 25, 2004 | 10:04 AM
Smooth-GSR's Avatar
Default Re: DSM 450's question..... (nextelbuddy)
Thanks!
Ya I have a resistor box, just wasn't sure about the clips. I'll have to get a set with them included. Or get the clips from an obd 1. What cars should I look for... sorry, I'm a turbo newb...
Thanks again!!!
Old Mar 25, 2004 | 10:07 AM
grndcont's Avatar
rc engineering sells them for cheap
Old Mar 25, 2004 | 04:17 PM
Smooth-GSR's Avatar
Default Re: (grndcont)
Thanks everyone.
Does it matter if they are 1g dsm or 2g dsm injectors, one are blue tops and the other are black tops.... besides the clips, do I need anything else to install them? Do I need seals of some sort....
Old Mar 25, 2004 | 08:52 PM
ImportHatch's Avatar
Default Re: (Smooth-GSR)
weird, I used the obd0 clips because they clipped right on. I have a z6 in my crx, obd1 wiring and spliced in the obd0 injector clips.
Yager-
Old Mar 25, 2004 | 08:55 PM
HXMan's Avatar
Get the RC engineering clips...DSM clips are a PITA to disconnect...
Old Mar 25, 2004 | 09:55 PM
ludelvr's Avatar
[QUOTE=nextelbuddy]you either need the DSM clips or a set of OBD1 injectors clips. but with the obd1 clips yo still ahve to cut out the little notch in the injectors to get them to fit perfectly.. QUOTE]
I'm not sure if all OBD1 clips are the same cuz on my 94 lude, the stock clips clip right on with no notching.
Old Mar 25, 2004 | 11:55 PM
Del_Slowest's Avatar
Default Re: DSM 450's question..... (ludelvr)
i have dsm ones for sale if you need them. just name a price, i don't need them
Old Mar 26, 2004 | 12:08 PM
Smooth-GSR's Avatar
Default Re: DSM 450's question..... (Del_Slowest)
Ok, I got 450's, the resistor box and a set of obd1 injectors so use its clips. Do I need anything else? Like seals? I read on another board that I do, but not much mention of that here....
Thanks again!!
Old Mar 26, 2004 | 12:15 PM
ITSTOCK's Avatar
Just bore out your injector seals that are in your intake manifold with a dremel, youll be fine.
Old Mar 26, 2004 | 12:19 PM
Smooth-GSR's Avatar
Default Re: DSM 450's question..... (ITSTOCK)
Thanks, is there a site with specific details, as I want to make sure they seat the same distance as stock....
Old Mar 26, 2004 | 10:16 PM
sibicguy's Avatar
http://www.homemadeturbo.com/t....html
95dc2teg
Jul 29, 2006 11:01 PM
SiR99
May 29, 2006 09:57 PM
Panoply
Jul 19, 2005 01:37 PM
Panoply
Jul 18, 2005 09:36 AM
Rare BlueSI
Sep 15, 2003 05:51 AM
