DSM 450cc how to:
Old Feb 21, 2010 | 05:51 AM
martial's Avatar
New User
Default DSM 450cc how to:
hi, im new and french guy so sorry for my english, but I just want know how to install my dsm 450cc black top on d16y8. I think I have to grind a little bit the OEM seals but what they have a other solutions..? same buy a o-rings seals and fit there with no modification.
and if you have a picture with . that will be awesome..
thank
Old Feb 21, 2010 | 06:02 AM
nowtype's Avatar
Default Re: DSM 450cc how to:
1) You will need OBD1, OBDO, or DSM injector clips to use DSM injectors.
2) You will need to install a resistor box, inline resistors, or an injector driver to run the injectors.
3) Take the stock seals and put them in the intake manifold. Put a very small amount of lube/petroleum jelly on the inside of the seals. Then push the injectors in by hand. You won't be able to get them in all the way, but you will be able to get them in a bit. Then put on the fuel rail. EVENLY and SLOWLY torque down the fuel rail. The injectors will slowly slide into the seals.
Old Feb 21, 2010 | 06:17 AM
martial's Avatar
New User
Im OBD1 ecu but.. your sure i have to take OBD1 clip injector because I read I can just remove the little clip on the dsm 450 injector and the OBD-2 injector clip can fit... And thank for the information
Old Feb 21, 2010 | 07:56 AM
nowtype's Avatar
You might know something I don't, but last I recall DSM injectors require OBD1, OBD0, or DSM injector clips.
The ECU doesn't matter. You still need a resistor box, injector driver, or inline resistors since DSM injectors are Low Z injectors and Hondas run High Z injectors.
BTW: Where in France are you from?
Old Feb 21, 2010 | 08:34 AM
martial's Avatar
New User
Im from Quebec... and I know I need a resistor box and i have one.
MBlake55
12
Jul 2, 2006 03:59 PM
b18c1wes
Dec 9, 2004 02:44 PM
Smooth-GSR
Mar 26, 2004 10:16 PM
Rare BlueSI
Sep 15, 2003 05:51 AM
